Error loading images over STAC connection in ArcGIS Pro
1795
01-15-2024 03:28 PM
Labels (2)
tempLeidyGarcía
Hello community, I have been testing the STAC connection for ArcGIS Pro, showing that results from various sources such as Sentinel, Landsat, among others, are not added to the map. Every time I try to add them I get an "Unknown Error" as shown in the screenshot.
Please could you guide me.
xingchenc
@tempLeidyGarcía
Hi Leidy, I believe I have encountered similar problem, please see my post for the solution(Solved: Re: Microsoft Planetary Computer STAC - unable to ... - Esri Community).
The key is to create a clould storage connection file and use it when creating STAC connection. You can download directly from here(arcgis-for-mpc/AMPC_Resources/ACS_Files at main · Esri/arcgis-for-mpc · GitHub) or you can follow the steps in the post to create one for yourself.
Hope this helps.
xingchenc
@tempLeidyGarcía
Hope this helps.
Youssef-Harby
Hi @tempLeidyGarcía and @xingchenc, I made a small tool that might be helpful here
It’s a Go-based proxy that handles the SAS token logic and CORS issues when using Microsoft Planetary Computer STAC with ArcGIS Pro. You just point ArcGIS to
http://localhost:8080/api/stac/v1/
and skip the manual ACS setup.
I put together a short tutorial (under 3 mins): https://youtu.be/CeIfDvK1F2U
Code repo: https://github.com/Youssef-Harby/ms-stac-proxy
Let me know if you try it out!
https://www.linkedin.com/in/youssef-harby/
Tags (1)
شرح سريع بيوضح إزاي تستخدم الـ STAC Proxy البسيط بتاعي عشان توصل ArcGIS Pro بـ Microsoft Planetary Computer، بدون الحاجة لإضافة SAS tokens يدويًا ولا مشاكل CORS، مجرد توصيل واشتغل على طول. رابط التحميل: https://github.com/Youssef-Harby/ms-stac-proxy/releases STAC (SpatioTemporal Asset Catalog) هو
