13 Band Unprocessed Sentinel 2 Imagery?
6087
8
07-31-2018 07:58 PM
SimonWebster
I'm looking to work with individual bands from the Sentinel 2 imagery, but seem to be unable to interact with more than three bands at a time in ArcGIS Pro 2.2.1 or ArcMap 10.3.1.
Loading either the Sentinel-2 Views from ArcGIS Pro Catalog (via AGOL), direct from the WMS/ArcGIS Rest Services (1, 2) yields the same 3 visible bands. I can, however, apply processing templates that come along with the rest service, as included with the attached image.
Is there a way to make use of all 13 bands via a WMS that doesn't require a subscription, or manually extracting and keeping an eye on AWS open source data sets? Ideally I'd like to have the bands available for custom raster function templates in ArcGIS Pro so that I can do slightly fancier things like urban fringe change detection on the fly.
Urban Index is available here, for example. And change detection is discussed here, and could be applied as a raster function template for on the fly viewing - if only we could see each of the 13 bands via the WMS.
CodyBenkelman
Load the service into the map
Go to table of contents, right click --> properties --> processing templates --> none
select layer in table of contents, go to Image Service Layer on toolbar and select Symbology
... and you can assign any band to the R and G and B displays
Note the Processing Templates provide faster access to the most common band combinations and indices (see 2nd screenshot above)
AbhijitDoshi
Simon,
set the processing templates as NONE, you will have access to all the 13 bands, Then you can apply your raster function templates to use any of the 13 bands
SimonWebster
Thanks Abhijit.
I did try that and it wasn't obvious that any more bands had become available.
I'll give it another try soon.
Is there any particular function where it should be obvious that all three bands are being delivered? Certainly the legend and raster info items still indicated three bands only.
Simon
Get Outlook for iOS<https://aka.ms/o0ukef>
CodyBenkelman
SimonWebster
*thirteen bands being delivered
LaurentPondevie
Anyone have success with custom functions like this Regolith Ratio;
(B11 / B12) + (B8 / B12) + (B8 / B3)
GuenterDoerffel
Laurent, what is your issue here? Not the results you expect? Without checking the literature:
Does  (B11 / B12) + (B8 / B12) + (B8 / B3)  refer to the band naming/order in the Sentinel doc?  Or is it (which would be crutial!)the band order in the dataset when in ArcGIS?
Please keep in mind that there is a Band 8A in sentinel - and counting this is band 9 - so all following are one number up!
So as a simple example: If you would need a formula like "NarrowNIR" / "Cirrus" in the sense of Sentinel doc this would be "8A" / "10" , but in the sense of band order in ArcGIS this would be "B9" / "B11"   !!
If that "error" happend on your formula above, the real formula most likely should be (B12 / B13) + (B8 / B13) + (B8 / B3)
Regards
Guenter
LaurentPondevie
Thank you Guenter. I'll take another look at my formula, but I think the issue is with the mix of band resolution that the Sentinel imagery is generated from. I beleive that there is a mix from 10m, 20m & 60m. So with my formulae I don't get the result I'm after. I'm comparing this to a standalone image that was created from resampled bands and then the formulae applied.
Look I'm not an expert by any means when it comes to Remote Sensing data, so I may be approaching this all wrong.
GuenterDoerffel
Laurent,
ArcGIS has settings to take care of this resolution issue: As a property of many band related functions you can specify your choice for the output cellsize type using the selector:
This is part of all math functions, too. If you have simplified the process and use the "user defined" Method of the Band Arithmetic function (which your question indicates), your mix of band-resolutions will be resolved as the "best available". I tested the line that I have suggested with Sentinel2 in "Band Arithmetic" and it works just fine:
RGB (4/3/2)
BandArithmetic Function: (B12 / B13) + (B8 / B13) + (B8 / B3)
Sorry - some city-patch - not ideal for regiolith
G.
