Site Scan for ArcGIS, Share/publish data to ArcGIS Online in defined coordinate system/tile schema
1504
12-17-2020 02:27 AM
Status: In Product Plan
ToreJensen2
New Contributor III
After processing drone data in Site Scan for ArcGIS, clients wants to share data to the rest of the organization using ArcGIS Online - and combine the drone products with other content. Today Site Scan only publishes data to ArcGIS Online in spatial reference 102100, regardless of what coordinate system is defined in the settings of the Site Scan project.  This causes problems for customers who have other data (especially raster / tiled products) that follow a different coordinate system / tile scheme. We need functionality in Site Scan so that the user can define which coordinate system / tile schema the data is published in when publishing to ArcGIS Online. An easy way to solve this could be for the user to point to a map service / basemap with the desired coordinate system / tile schema.
The workaround today is for the user to export the results from Site Scan (the export honor the coordinate system defined in the Site Scan project) and republish the content in the desired coordinate system / tile schema from ArcGIS Pro.
4 Comments
NicoBonnafoux
NicoBonnafoux
Tore, and to all who have a need for this functionality, please let us know which specific coordinate system(s) you need the Site Scan-ArcGIS connector/publishing functionality to work in.
ToreJensen2
Hi Nico,
In Norway we need at least support for spatial references 25832, 25833, 32633 and102100. Ideally, there should be support for all reference systems that the rest of the ArcGIS platform supports.
Br,
Tore
James_Wright
Hi Nico,
In New Zealand, the majority of users' content is in NZDG2000 / New Zealand Transverse Mercator (EPSG: 2193). It would be ideal to be able to publish directly in this coordinate system from Site Scan.
Cheers,
James Wright
