Processing Themal Imagery in Drone2Map
204
08-14-2020 11:47 AM
Status: Open
EduardoVasquez2
New Contributor II
487/5000
Currently Drone2Map processes the images from thermal sensors, however, the generated orthomosaic is not calibrated, that is, the raster does not present the pixel value in degrees centigrade (or Kelvin) but is an 8-bit image (0- 255). It would be very good if it could incorporate a processing template that allows obtaining the radiometrically calibrated image in degrees, in a similar way to how the Pix4D Mapper does using the Index Calculator.
