In Drone2Map, the data processing would often be very heavy an time consuming on a laptop, which a lot of people are working on. It would be a significant improvement if, the processing could be "outsourced" to a cloud environment or server environment.
So do the setup of the processing on your laptop/work environment and the processing itself on a stronger environment.
That would save a lot of time and improve efficiency.
