When I am trying to find the best places to go fishing and win tournaments I need to see where I am and I need the highest possible image resolution to make decisions.
"Wayback/Worldview" imagery provides high-resolution imagery that was acquired over many different times over many different years.
ArcGIS doe not allow me to harvest high-resolution image tiles in a way that I can use them.
Currently, I am forced to create Lowrance compatible map files using low-resolution Google Earth. Then I copy the files to SD cards and use them in the navigation hardware. I can buy SD cards that are pre-loaded with waterways directly from Lowrance but the resolution is not very good and the number of waterways that they offer is very limited.
I would like ESRI to integrate the Wayback/Worldview imagery directly into the Lowrance navigation hardware/software.
