Without an apply button, ArcGIS Pro is re-drawing the map for every symbology attribute change.
Example: Raster - Display Background Value - This part of the symbology pane has a check box and 3 fields to set the RGB values you want the change the display for.
Changing this sends 4 redraw requests to the map despite only 1 needing to be done.
I would prefer to have to click apply in all scenarios over having to deal with multiple redraws with no purpose.
Ryan Paquette I've marked this reviewed, I see what you're saying. However, it would be helpful for you to edit the idea's title to something like 'ArcGIS Pro: Add an Apply Button to Raster Symbology Pane"
Here is the symbology pane for a point feature. It has the apply button:
So this is specific to the symbology pane for raster data.
Thanks!
