I recently began testing drone software programs for the company I work for. We purchased a DJI product and collected field data, but as soon as I started testing several programs I discovered that there the same theme of not having the latest vertical coordinate system which is North American Vertical Datum (1988) or also known as NAVD88. I know that images can be projected, but that can be time consuming. It would be great if Drone2Map had the same coordinate system library choices as ArcGIS Pro and 10.7/8.
