Updated: January 19, 2023
This resource describes the vehicles, cameras, and lenses that are supported by the Site Scan Flight app. This also includes the latest test firmware version and supplemental camera configuration information.
Important Note: This resource applies to the Site Scan Flight app only.
Site Scan Manager (web-app) supports processing of virtually any georeferenced drone image.
If your drone is not supported by the Flight app, you may still use the manufacturer's application to capture images and upload them for processing and analysis in Site Scan.
Recommended Drones
Freefly Astro mapping kit
DJI Phantom 4 Pro v2
DJI Mavic 2 Pro
DJI Phantom 4 RTK with SDK controller
DJI Matrice 200 v2
Supported Drones
Vehicle | Supported Firmware | Supported Cameras/Lens Configurations | Notes |
DJI Phantom 4 Advanced
| 01.00.0600 & 01.00.0128 | Fixed Camera |
DJI Phantom 4 Pro
| 01.05.0300 & 01.05.0600 | Fixed Camera | - Phantom 4 Pro “+” (Plus) version with controller with a built-in screen is not supported |
| 01.00.5000 & 01.00.5200 | Fixed Camera | - Phantom 4 Pro “+” (Plus) version with controller with a built-in screen is not supported
DJI Phantom 4 RTK
| 02.02.0611 & 02.02.0616 | Fixed Camera
| - Requires SDK controller, controller with built in screen is not supported
DJI Mavic Pro
| 01.04.0400 & 01.04.0500 | Fixed Camera
| - Not recommended for high-accuracy mapping |
DJI Mavic 2 Pro
| 01.00.0670 & 01.00.0770 | Fixed Camera
DJI Matrice 200
| 01.02.0301 & 01.02.0450 | DJI Zenmuse X4S DJI Zenmuse X5S DJI Zenmuse XT Radiometric Temperature Camera (640 X 512, 30 HZ, 13MM) |
DJI Matrice 210
| 01.02.0301 & 01.02.0450 | DJI Zenmuse X4S DJI Zenmuse X5S DJI Zenmuse XT Radiometric Temperature Camera (640 X 512, 30 HZ, 13MM) Dual Configuration: - DJI Zenmuse X4S + DJI Zenmuse XT Radiometric Temperature Camera (640 X 512, 30 HZ, 13MM) |
DJI Matrice 210 RTK
| 01.02.0301 & 01.02.0450 | DJI Zenmuse X4S DJI Zenmuse X5S DJI Zenmuse XT Radiometric Temperature Camera (640 X 512), 30 HZ, 13MM) Dual Configuration: - DJI Zenmuse X4S + DJI Zenmuse XT Radiometric |
DJI Matrice 200 v2
| 01.00.0590 & 01.00.0710 | DJI Zenmuse X4S DJI Zenmuse X5S DJI Zenmuse XT 2 DJI Zenmuse X7 |
DJI Matrice 210 v2
| 01.00.0590 & 01.00.0710 | DJI Zenmuse X4S DJI Zenmuse X5S DJI Zenmuse XT 2 DJI Zenmuse X7 Dual Configurations: - DJI Zenmuse XT 2 + DJI Zenmuse X7 |
DJI Matrice 210 RTK v2
DJI Matrice 300 RTK
| 04.01.00.00 & 05.01.01.00 | DJI Zenmuse P1 |
DJI Inspire 2
| 01.02.0500 & 01.02.0600 | DJI Zenmuse X4S DJI Zenmuse X5S DJI Zenmuse X7 |
Freefly Astro
| 1.4.6 | Sony Alpha7R IV |
Supported Cameras
Camera | Specifications (recommended configurations) | Notes |
P4A Camera
| Sensor: 1” CMOS Effective pixels: 20M Lens Field of View (FOV): 84° Focal Length: 8.8 mm / 24 mm (35 mm format equivalent) Aperture: f/2.8-f/11 Shutter: Mechanical | Fixed camera |
P4P Camera
| Fixed camera
P4Pv2 Camera
| Fixed camera
P4RTK Camera
| Fixed camera
Mavic Pro Camera
| Sensor: 1/2.3” CMOS Effective pixels: 12.35M (Total pixels:12.71M) Lens Field of View (FOV): 78.8° Focal Length: 26 mm (35 mm format equivalent) Aperture: f/2.2 Shutter: Electronic | Fixed camera
Mavic 2 Pro Camera
| Sensor: 1” CMOS Effective Pixels: 20M Lens Field of View (FOV): ~77° Focal Length: 28 mm (35 mm format equivalent) Aperture: f/2.8-f/11 Shutter: Electronic | Fixed camera
X4S
| Sensor: 1” CMOS Effective Pixels: 20M Lens Field of View (FOV): 84° Focal Length: 8.8 mm / 24 mm (35 mm format equivalent) Aperture: f/2.0 Shutter: Leaf |
X5S
| Sensor: 4/3” CMOS Effective Pixels: 20.8M Lens Field of View (FOV): 84° Focal Length: 15 mm / 30 mm (35 mm format equivalent) Aperture: f/2.0-f/22 Shutter: Electronic
| - The lens listed is the recommended lens. Other lenses may function but will require manual focal length input in Advanced Flight Planning settings to correctly calculate overlap and sidelap.
| XT Version: Radiometric Lens Field of View (FOV): 45° Lens: 13 mm Camera Lens Max Thermal Frame Rate: 30 HZ Resolution: 640x512 Shutter: Mechanical | - The lens listed is the recommended lens. Other lenses may function but will require manual focal length input in Advanced Flight Planning settings to correctly calculate overlap and sidelap. |
DJI Zenmuse XT 2
| Sensor: 1/1.7" CMOS Thermal Imager: Uncooled VOx Microbolometer Lens Field of View (FOV): 45° x 37° Effective Pixels: 12M Max Thermal Frame Rate: 30HZ Resolution: 640x512 Shutter: Mechanical |
DJI Zenmuse X7
| Effective Pixels: 24M Sensor Size (Still): 23.5×15.7 mm Sensor Size (Max video recording area): 23.5×12.5 mm Lens Field of View (FOV): 84° Supported Lens: DJI DL 24 mm F2.8 LS ASPH (with lens hood and balancing ring/filter) / 36 mm (35 mm format equivalent) Shutter: Mechanical | - The lens listed is the recommended lens. Other lenses may function but will require manual focal length input in Advanced Flight Planning settings to correctly calculate overlap and sidelap. |
DJI Zenmuse P1
| Effective Pixels: 45M Sensor Size (Still): 35.9×24 mm Sensor Size (Max video recording area): 34×19 mm Lens Field of View (FOV): 63.5° Supported Lens: DJI DL 35mm F2.8 LS ASPH (with lens hood and balancing ring/filter) Shutter: Mechanical | - The lens listed is the recommended lens. Other lenses may function but will require manual focal length input in Advanced Flight Planning settings to correctly calculate overlap and sidelap. |
Sony Alpha7R IV
| Effective Pixels: 61M Sensor Size (Still): 35.7×23.8 mm Sensor Size (Max video recording area): 35.7×23.8 mm Lens Field of View (FOV): 84.1° Supported Lens: Sigma 24mm f3.5 mapping lens Shutter: Mechanical | - The lens listed is the recommended lens. Other lenses may function but will require manual focal length input in Advanced Flight Planning settings to correctly calculate overlap and sidelap. |
