Ortho Mapping in ArcGIS Pro: Getting Organized with a Workspace
2289
8
10-04-2018 09:31 AM
by Anonymous User
Not applicable
1 8 2,289
Any remote sensing image, whether it’s a drone image, aerial photograph, or data from a satellite sensor, will inherently be impacted by some form of geometric distortion. The shape of local terrain, the sensor angle and altitude, the motion of the sensor system, and the curvature of the Earth all make it difficult to represent three dimensional ground features accurately in a two dimensional map. Image orthorectification corrects for these types of distortion so you can have a measurable, map-accurate image.
Distortion caused by camera tilt and terrain displacement
Everyone working with GIS data to make well-informed decisions needs up-to-date information about the natural, man-made, and cultural features on the ground: roads, land cover types, buildings, water bodies, and other features that fill the landscape. Much of the vector data that describes these features was actually created from orthorectified imagery, and can be combined with new imagery to update your landbase.
A landbase is a layer or combination of layers making up the backdrop of your GIS
Esri’s Ortho Mapping suite enables you to orthorectify your remote sensing imagery to make it map-accurate. It also makes it easy to create other products like orthomosaics (mosaicked images corrected for distortion) and digital elevation models (terrain or surface models) which can be used as basemaps, part of a landbase, or for further analysis in stereo models, 3D analysis and feature extraction.
The workflow to create ortho mapping products will be presented in a three-part blog series, each with a short video:
  • Creating a workspace
  • Performing a block adjustment
  • Creating ortho mapping products
Let's get started!
Creating an Ortho Mapping Workspace
The first step in any project is getting organized – and creating an Ortho Mapping Workspace in ArcGIS Pro makes this easy to do.
The Ortho Mapping Workspace is a sub-project in ArcGIS Pro; it’s the interface you work with when interacting with ortho mapping workflows. The workspace is defined by the type of imagery you are working with (drone, aerial or satellite). In turn, the workspace is integrated with the tools and wizards to properly guide you through each step in the workflow. When you create a new workspace, an Ortho Mapping folder appears in your project folder structure in Catalog, and a new table of contents list view allows you to List By Ortho Mapping Entities. Again, the types of feature classes and tables you see in the Contents pane depend on the type of imagery you are working with.
Similar to Maps or Scenes within a project, a workspace is an object stored in the folder structure of a project and it can be accessed by other projects. All the feature classes and tables needed to orthorectify your imagery are created and managed in the workspace.
5 Simple Steps
Step 1: Open the Imagery tab in your ArcGIS Pro project. This is where you can analyze and manage any raster data you want to work with in Pro. In the Ortho Mapping group, you’ll see the New Workspace menu that allows you to create a New Ortho Mapping Workspace, add an existing Ortho Mapping Workspace with a reference to that workspace, or import an Ortho Mapping Workspace by creating a copy of an existing workspace and storing the new copy in your project. Select New Workspace.
Step 2: The New Ortho Mapping Workspace wizard appears. Here you’ll give your workspace a name (required) which identifies your project in the Contents and Catalog panes. You can also provide a description (optional) and you’ll select the type of imagery you want to import. In our workflow, we’re using aerial imagery acquired by Vexcel Imaging covering an area over Hollywood, California, so we’ll select Aerial – Digital as the type. Click Next.
Step 3: The Image Collection page opens. Here you’ll enter specific information about the type of sensor used to collect your imagery. You can choose from MATCH-AT, ISAT, or Applanix, or you can select the Generic Frame Camera, which requires you to provide the exterior and interior orientation information with the Frames tables and Cameras tables, respectively. Entering the Frames and Cameras information will provide the information necessary to correct for sensor-related distortion.
The Frames table has a specific schema that is required in the ortho mapping workspace for aerial imagery. It contains the exterior orientation and other information specific for each image comprising your image collection. The Cameras table contains all the camera calibration information for computing the interior orientation, but you can add the camera information manually in the wizard or as a table. To edit the Camera parameters, you can hover over the Camera ID and click the Edit Properties button. You’ll also need to specify the Frame Spatial Reference, which be provided with your data.
In this workflow, we used the exterior orientation information that was provided along with our source imagery to create the Frames table in the necessary schema. We then pointed to a table that has the information for one camera, with CameraID = 0 (see the screen shot below - there's a check mark next to the 0 under Cameras).
*We are updating this for ArcGIS Pro 2.3 to be more user-friendly for a better experience!
Step 4 To correct for terrain displacement, you need to include an elevation source. The cool thing about working with the ArcGIS platform is you can access the thousands of maps, apps and data layers available in the ArcGIS Living Atlas, so if you don’t have your own elevation data you can search for one and use it into your project. Here’s what we did:
  1. In our ArcGIS Pro project, zoom to the area of interest in Hollywood.
  2. On the Map tab, click Add Data and add data to the map.
  3. Select the Living Atlas option under the Portal group and search for "Terrain." Add the Terrain imagery layer. At first, you might not be able to see much variation in the terrain. Click on the Appearance tab under the Image Service Layer group and select DRA (Dynamic Range Adjustment) to stretch the terrain imagery in the extent you are viewing.
  4. In the Contents pane, right-click on the Terrain imagery layer and select Data > Export Raster.
  5. In the Export Raster settings, specify the output raster dataset and set the Clipping Geometry to the Current Display Extent.
  6. Click Export.
               Now we can add our new DEM to the workspace. To do this, open the Data Loader Options pane in the Image                Collection page. Click the browse button to navigate to the DEM created above, or use your own DEM.
               Step 5: Finally, we left all the other values as default and clicked Finish.
Log window will tell you how the creation of the workspace is coming along, and if there are any problems, an error message will be displayed. When it’s complete, you’ll see the new Ortho Mapping Entities in your Contents pane:  various control points including Ground Control Points, Check Points and Tie Points, the mosaic dataset that was created using your source data, and placeholders for Data Products, Solution Data, and QA/QC Data that haven’t been created yet.
Make sure to zoom and pan around the map to check out your Image Collection. With the Image Collection selected in the Contents pane, you can open the Data tab from the Mosaic Layer context menu. Here you can change the Sort and Overlap options for your mosaic dataset. We recommend using the Closest to Center or Closest to Nadir options for viewing.
Now that you have all your ortho mapping components organized in your workspace, the next step is to block adjust your data to make sure it’s map-accurate. Stay tuned for the next part of this blog series, Ortho Mapping with Aerial Data Part II: Getting Adjusted, where we’ll show you how to perform a block adjustment to make sure your data is ready for product generation and stereo compilation!
We showed you how to set up an ortho mapping workspace for aerial imagery. For an example of how to set up an ortho mapping workspace for satellite data, check out this short video!
Many thanks to Jeff Liedtke‌ for co-authoring this article!
8 Comments
AdamBarnes
Hi - I'm working with historic aerial photos and I have camera calibration values for radial distortion. These values not K0, K1, etc but rather radial distances (field angle in degrees, e.g. 7.5, 15, 22.5, ...) and distortion values (in micrometers, e.g. -5, -7, 2) for four separate azimuth angles (0, 90, 180, 270), so 24 total values. An example of this type of table can be seen on page two of the pdf here.
According to the Camera table schema from ESRI (link here), with this type of radial distortion information I should include a field for "DistortionType" and specify "DistortionTable" within this field. Then I should include two corresponding fields, "RadialDistances" and "RadialDistortions" that store "semicolon-delimited radial distances indicated as an ordered set of N values <r>. Each r distance value has a corresponding d distortion value in the RadialDistortions field."
My question: Can you supply an example of exactly how these values should be formatted? Should RadialDistances contain a string like, "7.5[0];15[0];22.5[0];30[0];35[0],40[0],7.5[90],15[90],..." with all 24 possible pairs? And, if that's right, the RadialDistortions field would contain a string like, "-3[0],-7[0],-6[0],-1[0],4[0],3[0],-3[90],-7[90],..." with all 24 distortion values?
Thanks for any help on this!
HongXu
by Esri Contributor
Adam,
The camera report you included does not have radial distances, but these can be calculated from the field angles using this formula: distance = focal length * tan(field angle)
The values for the fields can be set as below and the unit is um.
        20169.95;41051.42;63460;88453.53;107276;128555.1  for RadialDistances
        -4;-7;-7;-1;3;4 for RadialDistortions
you can actually avoid the hassle using the user-friendly wizard by clicking the "+" button next to the camera, and fill in the distortion table as below
Hope this helps,
Hong Xu
AdamBarnes
Hong,
Thanks for the reply. After some experimentation, I did eventually find that ArcGIS Pro would accept the values after converting the angles to microns. It's nice to hear that microns are in fact the correct units.
I'm using ArcGIS Pro 2.2.4 and I do not see the "+" button for adding new cameras in the "New Ortho Mapping Workspace" window. That's ok - using the RadialDistance and RadialDistorition attributes will work better for us I think.
We have now hit some other road blocks, however, and are about to give up on ArcGIS Pro. Should we contact customer support to start a support ticket or is there a way I can communicate with you over email?
Thank you.
New workspace
by Anonymous User
Not applicable
Hi Adam! The best move would be to open a case with Esri Technical Support. We will work with them collaboratively to help you as much as possible.
Esri Support Contact Support
GabElburn02
New Contributor II
I created a project with an Ortho Mapping workspace on my computer and now I need to move everything over to the server. Can I just cut and paste the project folder over? or do I need to:
1) Create a new project on the server;
2) Import the Ortho Mapping workspace and all it's supporting files?
Please let me know if the cut and paste is an ideal way to go?
Thanks!
mingzhenC
New Contributor II
Are you going to move to a Server machine or an ArcGIS Server?
GabElburn02
New Contributor II
Hi @mingzhenC , to a Server machine. Thanks!
mingzhenC
New Contributor II
To Server machine, you can do both way which you mentioned. Don't forget to repair the data path after copying project.
