The ArcGIS Pro 2.3.2 software patch enables mosaic datasets created or modified by Pro 2.3 and 10.7 to be read and modified by earlier versions (ArcGIS Pro 2.1 and 10.5 or later).
If you created or modified a mosaic dataset using Pro 2.3 or 10.7, you can update it and make it compatible with earlier versions by following the steps below.
This resets the mosaic dataset object to the new Pro 2.3.2 version.
Update to ArcGIS Pro 2.3.2 by going to My Esri or by using the in-app software updater.
