Departmental Licensing.
I administer a University Departmental License (50 licenses). I can manage ArcGIS Online accounts (create, modify, delete). Can I do the same for ArcMap? I have 50 licenses (one code which counts the licenses). Once given, is it revocable or will it be available for the duration of the license? I want to use the same 50 for my classes each semester.
Dan
Dan,
You mentioned you have one code with 50 licenses. Does the authorization code start with an EFL or ESU? If it starts with EFL, you have a Concurrent Use license. In this case, you will need to install a license manager where you can authorize and host the licenses. ArcMap will point to the license manager for the licenses.
If your code starts with ESU, you have a Single Use license. You can use the code to authorize the license on the individual machine. The only way to retrieve it back is to deauthorize it from the authorized machine.
Let me know what license type you have and if you have further question.
