Configuring AWS S3 Bucket for use with webgisdr
1925
6
04-21-2021 08:51 PM
DeanHowell1
I am trying to create a new backup using webgisdr and running into some issues with the S3 bucket being validated by webgisdr.
I created an S3 bucket and just let everything default and then referenced the name of the S3 Bucket in the batch file that has been set-up to run the webgisdr but when I run it, I get the following error reported in the log.
Starting the WebGIS DR utility.
Failed to validate to the Amazon S3 bucket beta-spatial-webgisdr-backup. Please check the Web GIS DR log for more information.
Exiting the WebGIS DR utility.
Thu 04/22/2021 3:41:11.68 -- Finished -------------------------------------------------
What is webgisdr needing for the S3 bucket to be validated correctly?
Tags (3)
ReeseFacendini
@DeanHowell1  here is where I got that information Create an ArcGIS Enterprise backup—Portal for ArcGIS | Documentation for ArcGIS Enterprise.  I believe you are right, that copying the IAM Role should work
ReeseFacendini
When filling out the WebGISDr properties file, did you also set the AccessKey, SecretKey, Credential_Type, etc?  Or only set the name of the bucket?
DeanHowell1
Thanks @ReeseFacendini no didn't set any credentials. Where do you get that info from?
DeanHowell1
Hello again @ReeseFacendini , the properties file is directly referencing an IAM role as the credentials.  I am guessing if I can find out the role used in the other profile and set that IAM role up it should work 🙂
ReeseFacendini
JonathanQuinn
Esri Notable Contributor
Is beta-spatial-webgisdr-backup the backup bucket for the content, or for the backup itself? Is it in a separate region? If so, can you delete the VPC endpoint, which prohibits cross-region copying?
DeanHowell1
Thanks @JonathanQuinn the name is the S3 bucket name and it is in the same region.
