Portal Tier Authentication with Windows Active Directory Accounts in Highly Available ArcGIS Enterprise
2377
07-21-2021 03:51 PM
BenjaminBlackshear
I have deployed ArcGIS Enterprise 10.8.1 and configured it for high availability. I have a few questions to ensure the deployment is configured correctly as I am trying to use a setup that isn't mentioned in any of the deployment patterns.
I am using a slightly modified version of this deployment pattern:
Machine 1 is running portal (primary), server, data store (primary), and 2 web adapters (portal and server)
Machine 2 is running portal (secondary), server, data store (secondary), and 2 web adapters (portal and server)
The two ArcGIS Server installations have been joined and are operating as one site which is federated with the portal using the load balancer url.
I am not planning to use IWA with my highly available portal, I want to use Active Directory accounts with portal authentication as described here: https://enterprise.arcgis.com/en/portal/10.8/administer/windows/use-your-portal-with-ldap-and-portal...
I have not seen this configuration described in any of the high availability documentation or deployment scenarios, is this supported for highly available deployments? It is working fine now, I just want to confirm that it will not create problems later or expose me to any security risks.
2 Solutions
Todd_Metzler
My configuration is the same as yours except the high availability.  Has been working just fine for over a year.  Run PortalScan and ServerScan and address any reported security issues that concern you.
TIP:  Work closely with your Active Directory Administrator to ensure the advertised attributes for named users conform to the structure expected by ArcGIS Enterprise.  In my config, we advertise user.name@domain instead of user.name@email.com(net)(gov)(...).  That initially caused ArcGIS Enterprise sign in confusion for our users.  What I did to address that was standardize the sign in to user.name@domain in every component of ArcGIS including AGOL and web mobile apps.
DavidHoy
Hi Benjamin
yes your HA configuration will work fine.
Todd's suggestion is useful in specific AD configurations - check with your organisation's AD Administrator to be sure.
Todd_Metzler
BenjaminBlackshear
Thanks Todd!
@DavidHoycan you confirm that this is supported for highly available deployments as well?
DavidHoy
Hi Benjamin
BenjaminBlackshear
Great, thanks for your help!
