Do I need to rebuild map service cache?
1779
10-03-2019 11:26 AM
BrianCunningham2
I'm not sure if this is a dumb question or not... but I'm still learning the ropes with cached map services.
We are migrating to a new SQL Server and I'm curious if I need to rebuild my map service caches because of that?  The database name, feature class names and feature class structures are staying the same; the data is not changing; the only thing that is changing is the name of the server that is housing the database.
Can I simply re-publish the map services that are pointing to the new server, or do I need to completely rebuild caches for any map services that have them?
Brian
George_Thompson
Esri Notable Contributor
George_Thompson
I would say nope, as long as nothing on the data side is changing.
https://enterprise.arcgis.com/en/server/latest/publish-services/windows/copying-caches.htm
Enterprise GIS‌ ArcGIS Enterprise
--- George T.
MichaelVolz
Esteemed Contributor
Theoretically you should not have to, but the cache has never displayed properly for me if I use it in multiple versions.  I would say give it a shot as this is the quickest and easiest path to get a cached mapservice on a new machine.  If it does not work, you can always build the cache from scratch.
BrianCunningham2
Thanks for the responses guys - I'll let y'all know how things work out for me.
Much appreciated,
Brian
BrianCunningham2
So far the cache has continued to work for me after changing the data source to the new server.
Thanks for the input.
