Hello @ChristopherPawlyszyn,
Apologize for my late reply. I have been working hard on trying to make it work.
Unfortunately, it does not. I wonder if there is not another BUG on top of the "DIRECT_FILE_BACKUP" one.
If, as you suggested, I tried to unregister the datastore and restore it manually using "restoredatastore" command following this article:
https://support.esri.com/en-us/knowledge-base/how-to-restore-arcgis-data-store-000021700
I have the following error:
Error encountered: Machine 'https://GISSTORE.COMPANY.COM:2443/arcgis/datastoreadmin' returned an error. 'Failed to restore 'tile cache' data store.
Caused by: null'
Unfortunately, using this method, I don't have anything in the logs. Seems like the fact that ArcGIS Server in the DEBUG mode is not taken into account.
I tried also several times to restore the full webgisdr backup using the following workflow:
- Initializing new VMs from scratch
- Installing and configuring ArcGIS Enterprise 11.1 components on each VM using ArcGIS powershell DSC as if it was prod
- At the end, the standby ArcGIS Enterprise deployment is functionnal
- Restore 11.1 webgisdr done from production with tileCache backup configured as "REPLICATION_BACKUP" (I doubled check the metatadata file and it is a "REPLICATION_BACKUP" tileCache)
After that, relational datastore is successfully restored but the tileCache one fails after a while with all the time this error:
"jobId": "329f74b3-45d2-40f2-a267-599f1941214e",
"errorMessage": "Failed to register tile cache data store.\nCaused by: The specified GIS Server site already has a tile cache data store.",
"description": "Deploy data store snapshot 20231125-020011-08-FULL from \\\\myser\\WebGISSite1701272254236\\dataStore\\a3729eb8-a53e-4ac5-88a4-d90a56801b3b",
"lastModified": "2023-11-29 18:52",
"status": "failed"
In the arcgis datastore server logs:
<Msg time="2023-11-29T18:20:33,793" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Applying WebGIS DR snapshot for tile cache data store...</Msg>
<Msg time="2023-11-29T18:20:37,821" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Stopping nonsql database </Msg>
<Msg time="2023-11-29T18:20:37,821" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">NoSQL database was stopped </Msg>
<Msg time="2023-11-29T18:33:01,1" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">prepare for tile cache data store configuration...</Msg>
<Msg time="2023-11-29T18:33:01,1" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Configure vm.args...</Msg>
<Msg time="2023-11-29T18:33:01,7" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Prepare default.ini...</Msg>
<Msg time="2023-11-29T18:33:01,18" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Prepare SSL certificates...</Msg>
<Msg time="2023-11-29T18:33:01,303" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Configure D:\arcgis\arcgisdatastore\nosqldata\etc\local.ini...</Msg>
<Msg time="2023-11-29T18:33:02,335" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">configuring tile cache data store...</Msg>
<Msg time="2023-11-29T18:33:04,850" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">create user usr_83dhi...</Msg>
<Msg time="2023-11-29T18:33:05,884" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">create tile cache site store if needed ...</Msg>
<Msg time="2023-11-29T18:33:08,350" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Register new title cache data store...</Msg>
<Msg time="2023-11-29T18:33:17,834" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Performing restore on a existing tile cache data store...</Msg>
<Msg time="2023-11-29T18:33:17,850" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Found backup set specified:DEFAULT_LOCAL</Msg>
<Msg time="2023-11-29T18:33:17,850" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Validate storage store for the source backup store...</Msg>
<Msg time="2023-11-29T18:33:17,850" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Validate source backup set...</Msg>
<Msg time="2023-11-29T18:33:17,881" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">prepare for tile cache data store configuration...</Msg>
<Msg time="2023-11-29T18:33:17,881" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Configure vm.args...</Msg>
<Msg time="2023-11-29T18:33:17,881" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Prepare default.ini...</Msg>
<Msg time="2023-11-29T18:33:17,881" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Prepare SSL certificates...</Msg>
<Msg time="2023-11-29T18:33:17,991" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Configure D:\arcgis\arcgisdatastore\staging\tileCache\tcs_2jikygfh\etc\local.ini...</Msg>
<Msg time="2023-11-29T18:52:43,162" type="WARNING" code="110379" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Failed to restore 'tile cache' data store. null</Msg>
<Msg time="2023-11-29T18:52:43,162" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">com.esri.arcgis.datastore.common.DataStoreException
at com.esri.arcgis.datastore.model.couchdb.CouchDBManager.restore(CouchDBManager.java:8270)
at com.esri.arcgis.datastore.client.DataStoreAdminClient.b(DataStoreAdminClient.java:4857)
at com.esri.arcgis.datastore.client.DataStoreAdminClient.restore(DataStoreAdminClient.java:3796)
at com.esri.arcgis.datastore.client.DataStoreAdminClient.a(DataStoreAdminClient.java:12829)
at com.esri.arcgis.datastore.client.DataStoreAdminClient.deployWebGISSnapshot(DataStoreAdminClient.java:11771)
at com.esri.arcgis.datastore.client.DataStoreAdminClient$e.run(DataStoreAdminClient$e.java:10906)
at java.base/java.lang.Thread.run(Unknown Source)
</Msg>
<Msg time="2023-11-29T18:52:43,162" type="SEVERE" code="111002" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Failed to import data to your replicated site. Failed to restore 'tile cache' data store.
Caused by: null</Msg>
<Msg time="2023-11-29T18:52:43,162" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">com.esri.arcgis.datastore.common.DataStoreException: Failed to restore 'tile cache' data store.
Caused by: null
at com.esri.arcgis.datastore.client.DataStoreAdminClient.restore(DataStoreAdminClient.java:3801)
</Msg>
<Msg time="2023-11-29T18:52:43,162" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Stopping nonsql database </Msg>
<Msg time="2023-11-29T18:52:43,162" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">NoSQL database was stopped </Msg>
<Msg time="2023-11-29T18:52:48,85" type="WARNING" code="110804" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Failed to register tile cache data store. The specified GIS Server site already has a tile cache data store.</Msg>
<Msg time="2023-11-29T18:52:48,85" type="DEBUG" code="9999" source="Data Store" process="9136" thread="36" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">com.esri.arcgis.datastore.common.DataStoreException: The specified GIS Server site already has a tile cache data store.
at com.esri.arcgis.datastore.model.couchdb.CouchDBManager.registerDataStore(CouchDBManager.java:661)
at com.esri.arcgis.datastore.client.DataStoreAdminClient.registerTileCacheDataStore(DataStoreAdminClient.java:13919)
at com.esri.arcgis.datastore.client.DataStoreAdminClientForServer.registerDataStore(DataStoreAdminClientForServer.java:2843)
at com.esri.arcgis.datastore.client.DataStoreAdminClientForServer.registerDataStore(DataStoreAdminClientForServer.java:2744)
at com.esri.arcgis.datastore.client.DataStoreAdminClient.a(DataStoreAdminClient.java:13026)
</Msg>
When this occurs, I unregister the datastores from ArcGIS Server manager and uninstall ArcGIS datastore from the VM, rename installed folder "ArcGIS", rename the "arcgisdatastore" content folder,
reinstall 11.1 datastore, do not configure it, and try a manual restore using "restoredatastore" but it fails as mentionned before. Also, it seems to me that the error:
is misleading because it occurs after the following error and I don't think it is the root cause of the restore failing:
I also tried the following workflow:
- Installing and configuring ArcGIS Enterprise 11.0 components on each VM using ArcGIS powershell DSC as if it was prod
- At the end, the standby ArcGIS Enterprise 11.0 deployment is functionnal
- Restore the last 11.0 webgisdr backup done from production. At the time "REPLICATION_BACKUP" was the default
- At the end, webgisdr restore work fine and my 11.0 deployment is perfectely. So I guess we can exclude an issue with my workflow as it works perfectely at 11.0
- Upgrade deployment to 11.1
After that, relational datastore is successfully restored but the tileCache one fails with the same error as with "restoredatastore" command:
<Msg time="2023-12-01T12:21:24,172" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Applying WebGIS DR snapshot for tile cache data store...</Msg>
<Msg time="2023-12-01T12:21:24,277" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Performing restore on a existing tile cache data store...</Msg>
<Msg time="2023-12-01T12:21:24,326" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Found backup set specified:DEFAULT_LOCAL</Msg>
<Msg time="2023-12-01T12:21:24,326" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Validate storage store for the source backup store...</Msg>
<Msg time="2023-12-01T12:21:24,326" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Validate source backup set...</Msg>
<Msg time="2023-12-01T12:21:24,421" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Failed to cleanup the staging directory for tilecache data store...</Msg>
<Msg time="2023-12-01T12:21:24,421" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">prepare for tile cache data store configuration...</Msg>
<Msg time="2023-12-01T12:21:24,421" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Configure vm.args...</Msg>
<Msg time="2023-12-01T12:21:24,433" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Prepare default.ini...</Msg>
<Msg time="2023-12-01T12:21:24,433" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Prepare SSL certificates...</Msg>
<Msg time="2023-12-01T12:21:24,792" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Configure D:\arcgis\arcgisdatastore\staging\tileCache\tcs_2jikygfh\etc\local.ini...</Msg>
<Msg time="2023-12-01T12:26:02,844" type="WARNING" code="110379" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Failed to restore 'tile cache' data store. null</Msg>
<Msg time="2023-12-01T12:26:02,844" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">com.esri.arcgis.datastore.common.DataStoreException
</Msg>
<Msg time="2023-12-01T12:26:02,844" type="SEVERE" code="111002" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">Failed to import data to your replicated site. Failed to restore 'tile cache' data store.
<Msg time="2023-12-01T12:26:02,844" type="DEBUG" code="9999" source="Data Store" process="1152" thread="32" methodName="" machine="GISSTORE.COMPANY.COM" user="" elapsed="" requestID="">com.esri.arcgis.datastore.common.DataStoreException: Failed to restore 'tile cache' data store.
Caused by: null
</Msg>
Could you please help ? What do you think could be the issue ? Should I open another ticket ?
Nicolas
