I have a shapefile layer showing the City of Austin site plans as polygons. The idea is when someone clicks on the polygon, a pop up would show the Google Street View of the property, a couple of the fields from the record, and a custom URL to the City of Austin website to view more details on the site plan. I have been trying to knock this out for hours, any insight would be greatly appreciated.
City of Austin website link details:
Here is the first part of the URL: https://www.austintexas.gov/devreview/b_showpublicpermitfolderdetails.jsp?FolderRSN=
After the =, I need to populate the data from a field in the shapefile. The field is called folderrsn
So everything put together would look like this: https://www.austintexas.gov/devreview/b_showpublicpermitfolderdetails.jsp?FolderRSN=10880075
The "10880075" is the value currently inside the field folderrsn.
You could use this tool I created GoogleTool.esriaddin
You could also populate the URL below in a field to do the hyperlink or popup
"http://data.mapchannels.com/mm/dual2/map.htm?x=" + str(adx) + "&y="+ str(ady) + "&z=16&xb=" + str(adx) + "&yb="+ str(ady) + "&bar=1&mw=1&gm=0&ve=2&sv=1"#&svb="+ String(computeAngle2(startPt,lastPnt))
EDIT:
For the second part you can use the field calculator with the parser set to python
" https://www.austintexas.gov/devreview/b_showpublicpermitfolderdetails.jsp?FolderRSN=" + ! folderrsn!
I also found some old code that will populate the google street view url for a point file, see below.
import arcpy """ Create and store URL for Google street view of address points""" #Address Points addrs = r"Your feature class here" #Create Spatial Reference sr = arcpy.SpatialReference.FactoryCode = 4326 #Create Cursor and set Spatial Reference of cursor so xy is in decimal degrees adRows = arcpy.UpdateCursor(addrs,"",sr) #Loop through each address point and create url with address point xy for ad in adRows: adPt = ad.Shape pnt = adPt.getPart() #Change pictures to your field name ad.pictures ="http://data.mapchannels.com/mm/dual2/map.htm?x=" + str(pnt.X) + "&y="+ str(pnt.Y) + "&z=16&xb=" + str(pnt.X) + "&yb="+ str(pnt.Y) + "&bar=1&mw=1&gm=0&ve=2&sv=1"#&svb="+ String(computeAngle2(startPt,lastPnt)) adRows.updateRow(ad)
Wes- I just tried the tool you sent. I followed the instructions and
installed it, now I am unable to open ArcMap. Not sure what to do. Would
you mind giving me a quick call to troubleshoot? 512.906.6757
I've never had that happen before. Try some of the normal stuff like: restart your machine, and rename your "Normal.mxt" mine is located ""C:\Users\<<yourusernamehere>>\AppData\Roaming\ESRI\Desktop10.2\ArcMap\Templates\Normal.mxt"
ok will do.
It didnt work. I am using 10.4. I wonder if thats the issue. Here is a
link to the video I just made showing I cant open the program.
https://www.dropbox.com/s/vn5y3h72pj6ios4/arc%20map%20wont%20start.mp4?dl=0
Do you know how to uninstall the tool without opening the program?
You may want to call tech support.
ok ;(
Wes- your tool crashed my esri desktop program and support has not
responded. I cant even open my program. Any ideas how to help?
Did you try calling them?
