How I Unified 10,000+ State ArcGIS REST Layers into a Real-Time Fisheries Intelligence API (ADF&G + PFBC + FWC)
372
10-30-2025 07:36 PM
carterfish
Hey everyone — I wanted to share a project I’ve been working on that heavily leverages ArcGIS REST endpoints from multiple state and federal agencies.
Over the past year I’ve built a 14-state data pipeline that unifies public ArcGIS REST services from:
- Alaska Department of Fish & Game (ADF&G)
- Pennsylvania Fish & Boat Commission (PASDA / PFBC)
- Maryland Fish & Wildlife (FWC)
- USGS Water Services API
Each state provides a unique challenge — different geometry types, coordinate systems, pagination rules, and field schemas. My pipeline normalizes these in TypeScript and outputs unified JSON for use in mapping apps and APIs.
Example use cases
- Alaska: 9,031 officially cataloged water bodies (ADF&G AWC API) + 222 real-time stocking records
- Pennsylvania: PASDA “Best Fishing Waters” + PFBC trout stocking database (real fish quantities and species)
- Florida: FWC MRGIS boat ramps + Fish Management Areas (polygon-to-centroid transformation)
- USGS: Real-time water temperature, dissolved oxygen, and pH enrichment
Technical highlights
- Web Mercator → WGS84 coordinate transformation
- ArcGIS REST pagination using `resultOffset` / `resultRecordCount`
- Parallel data fetching (`Promise.all`) for 10K+ features
- Layer normalization and enrichment with USGS live feeds
- Cached API response times: 53 ms (from 1.8 s initial load)
Here’s a visual example of the Alaska implementation (9,000+ locations):
👉 https://youtu.be/Xwdm5tY2XU8
I also wrote about how I enriched Minnesotas waters as well: https://medium.com/@jcdesign/how-i-scaled-minnesotas-fishing-intelligence-through-dnr-data-enrichmen...
If anyone here has worked on large-scale ArcGIS REST normalization or best practices for cross-state schema harmonization, I’d love to compare notes — especially around rate-limits, batch queries, and geometry simplification.
John Carter
My Website: www.fishdata.co
LinkedIn
We built the first real-time environmental intelligence pipeline for the largest and wildest state in America. 9,000+ verified fishing locations. Every river, lake, and harbor - mapped, normalized, and alive. From ADF&G to EPA, USGS to NOAA - harmonized into one connected system that finally sees
JesseCloutier
Esri Community Manager
This is really excellent, @carterfish -- thank you for sharing here in Esri Community! I'm curious: How long have you been using Esri Community and did it support or inform any of the work you've showcased in the video or your Medium story?
Jesse Cloutier
Community Manager, Engagement & Content
