Two more things you can do with Story Maps
3927
02-13-2017 04:03 PM
BernSzukalski
Esri Frequent Contributor
2 0 3,927
The list never seems to stop, here's two more things that you can do with Story Maps. The current list of 10 is here:
Ten things you didn’t know you could do with Story Maps | ArcGIS Blog
These will be added soon...
A Wedding Invitation
This Story Map Series (side accordion layout) is actually a wedding invitation, including everything from the event date, venue, and travel information to get there. Congrats to Jose and Segio!
A Web Page
Here are two examples of a Story Map Cascade as a web page. This first one from the International League of Conservation Photographers (ILCP). The header is fixed, the Cascade was embedded using an iframe.
This second example is from the USGS,and uses a standard USGS header and footer. It also embeds the Cascade using an iframe. Check out the page source to see how easy and simple this is. Great idea!
About the Author
Esri technical evangelist and product advocate. On a good day I'm making a map. On a great day I'm on one. https://www.linkedin.com/in/bernszukalski/ bszukalski@esri.com
