Summary of ArcGIS Server SSL Issues
7974
07-30-2015 06:14 AM
ThomasColson
MVP Frequent Contributor
10 4 7,974
This is really just to help me "bookmark" all of the SSL issues, as we're having many of them, hope it helps other folks out!
  1. Secure SSL services in Web App builder failing.
  2. ArcGIS Portal 10.3 - SSL Certificate for internal network QUESTIONS
    1. Includes a little-known REST checker that test certificate status: cool! https://%3Cserver.domain.com%3E:7443/arcgis/sharing/checkUrl.jsp?url=%3CinsertURLthatisboundtothecer...
  3. ArcGIS Portal 10.3 - SSL Certificate for internal network QUESTIONS
    1. Poster can't seem to get a cert working, explored using their own CA server
  4. Setting up SSL with a signed certificate in a multi-tier server architecture
    1. Take home message: use proper DNS Aliasing!
  5. SSL and esri/request
    1. Seems that enabling "HTTPS" only causes some app errors downstream
  6. Anyone else using SSL with AWS EC2 and elastic load balancer?
    1. Don't use Amazon ECW if you need PKI!
  7. Sharing Web GIS Services? Always enable TLS | ArcGIS Blog
    1. Another test of SSL functionality SSL Server Test (Powered by Qualys SSL Labs)
  8. how to use portalpy with win-authenticated SSL
    1. PKI- Portal doesn't work with python
  9. ssl certificate to publish the geoprocessing tool
    1. Enabling SSL breaks GP Tools
  10. ArcGIS Server with Reverse Proxy using IIS and SSL
    1. The horrors of reverse proxy
      1. 40694 - Set up a reverse proxy with ArcGIS 10.1 for Server on IIS ARR with SSL
  11. How many SSL certificates does ArcGIS Server need?
    1. Certs must use FQDN
  12. Issues enabling SSL and accessing with HTTPS
    1. Another confirmation that wild card certs don't work
  13. Is it necessary to enable SSL if the ArcGIS Web Adaptor forwards request 2 ServerSite
    1. SSL is required to encrypt passwords
  14. Creating SSL Certificates for ArcGIS Server - do i need to use AGS Admin Interface
  15. CA Signed SSL Installation with Web Adpater on IIS 7.5
    1. remember, ArcGIS Server is a separate Apache Web Server: Needs a trusted cert as well! AGIS Cert needs to be signed by trusted CA
  16. Latency on get token request via SSL (ArgGIS server 10.1 SP1)
    1. SSL kills performace. What a surprise.....
  17. Wildcard SSL installation help!
  18. Adding unsecured services
    1. This is a big problem: If organization requires HTTPS only, can't consume HTTP content in portal
  19. PKI auth. In portal with AD
  20. How to connect to a secure ArcGIS Server using HTTPS and a PKI (X509) Certificate
  21. Federating an ArcGIS Server site with your portal
4 Comments
RebeccaStrauch__GISP
Thomas, Thanks for putting this list together and sharing.  Although there isn't anything WAB specific, there are issues that come up when implementing, so I'm going to add a link to this page in the Web AppBuilder Developer Edition - Customization Resource List
MariusŽilėnas
good list addressing ssl issues
MarkSciuchetti1
New Contributor II
Thank you for this insightful list of knowledge. I will pass it along to a good friend of mine.
ThomasColson
Sasquatch is always glad to help
About the Author
This is a personal account and does not reflect the view or policies of my org.
