Group Indicators in ArcGIS Dashboards
1274
6
12-20-2019 06:53 AM
MikeSchoelen
Do you wish you could stack a whole bunch of indicators into a single tab in ArcGIS Dashboard? Just hold down the SHIFT key when stacking two indicators! The help text will turn green, and you will be able to group the two cards together, allowing them to behave as a single unit for stacking or rearrangement.
Holding the shift key while stacking cards allows you to group them into a single card.
6 Comments
NathanielSimmons
New Contributor III
Awesome, thanks for the tip!
Another thing that would make this even better is having a way to automatically resize all of the indicator boxes to the same size (at least when they are within the same panel/tab).
KevinWright3
New Contributor III
My thoughts exactly!  Additionally, it would be nice to be able to set a value for heights and widths instead of just eyeing it.
NathanielSimmons
New Contributor III
I created an idea for being able to resize the elements more consistently.
https://community.esri.com/ideas/17806-consistentlyautomatically-resize-operations-dashboard-element...
MichaelKellyTeck
I know it's a hack, but I usually alter the JSON via AGO Admin Assistant to get around this.
MikeSchoelen
A complete hack!
[I'm so proud of you]
MikeSchoelen
I believe ArcGIS Dashboards Beta introduces the functionality that addresses this
About the Author
Solution Engineer at Esri | Health & Human Services
