Do you wish you could stack a whole bunch of indicators into a single tab in ArcGIS Dashboard? Just hold down the SHIFT key when stacking two indicators! The help text will turn green, and you will be able to group the two cards together, allowing them to behave as a single unit for stacking or rearrangement.
Holding the shift key while stacking cards allows you to group them into a single card.
