Preparing Georgia's Counties to Run Hazus Risk Assessments
198
12-21-2016 08:23 AM
Session run by Hunter Key, GIS Manager at Georgia Coastal Regional Commission
Agenda
May 19th – May 21st
Hazus Translator Process
Objective: To collectively work through the Data Interoperability process translating Local WinGap data to Building Inventory data. This class will work through the first 2 parts of the workflow created by The Polis Center. Specifically working with the Data Sources and Inventory. Sections III and IV focus on utilizing HAZUS-MH software to update the data into HAZUS and then run the Risk Assessment and were  covered in earlier training.
Day 1 – Monday December 19th
10:00 am – Introduction / system set up / overview of the manual
                Attendees will need to bring the following
  1. Computer Aided Mass Appraisal (CAMA) date export from the county they will be working on. (If you have more than one county and have more than one person from your RC attending it may be a good idea to work on different counties)
  2. Parcel geometry for the county they will be working on
  3. Data Interoperability extension installed on their computer ( I have a request out to ESRI for demos so all can work through the workflow)
  4. Download and install the Bulk Rename Utility   http://www.bulkrenameutility.co.uk/Download.php
  5. Download the RegionW_2 – WinGap Template folder from the drop box (this will be uploaded just prior to the session with a new manual) https://www.dropbox.com/sh/vzw1ayvwppn3516/AADzgSmIxAbv7LycTLm0-HBQa?dl=0
11:00 – Orientation to the FME Workbench environment
11:30 -  Task 1.1.1 & Task 1.2 in the Workflow manual
                Task 1.1.1 – Create Region W from Templates
                Task 1.2  - Download Data sources
12:00 – Lunch on your own ( If we want to do a small registration fee $30 ? CRC can order and get food options for the 3 days)
1:30 pm – Finish exercises to complete Task 1.1.1 & 1.2
2:00  pm – Task 1.3 Install Hazus Updates – Discuss the Essential Facilities data
At the GA URISA conference in November 3- 5 I met with Lawton and Jimmy at ITOS regarding this project. They indicated some trepidation by GEMA with the current state of Essential Facilities.  We will discuss this and move forward accordingly.
2:30 pm – Task  1.4 Export Boundaries.
3:00 – 5:00  pm – Task 1.5  Create Buildings
                       Task 1.5.0  - Make CAMA tables – Discuss best practices and common issues for errors.
                        Task 1.5.1  - Make CAMA Domains –
                      Task 1.5.2 – Create impCama – Look in-depth at the at the database structure and set up for re-using the structure for future tasks.
Day 2 - Tuesday December 20
8:30 am – Task 1.5.2 – Continue working on the set up
                    This is the most labor intensive step  where the user must assign a hzOccCode to the counties data. This is subjective but we collectively need to be similar.
11:30 – Lunch
12:30 – Task 1.5.2 – Load the edited Matrix tables into the transformer 12_Make_ImpCAMA
2:00 pm Task 1.5.3 – Create impPoints
3:00  - 5:00 pm Task 1.5.4 – Make Buildings - **Important note** editing the Attribute Copier and the added value of “assessment year”
Day 3 - Wednesday  December 21
8:30 am – Task 1.5.5 QC Buildings
9:30 am – Discuss and go over QC results
10:00 am – Discuss the types of transformers and highlight the “value mapper” transformer and what tools require attention to the value mapper.
11:30 am – Group choice work through the Essential Facilities tools or work through the Extended Products tools (Parcel, Land Use, Addressing)
12:00 – lunch
1:00 – 5:00  pm – Essential Facilities or Extended Products.
1 Comment
Additional info from Hunter:
All,
Below is some resources for  the FME tools. The second link is to a nifty reference guide that I have found helpful.
The real reason for the e-mail however is for you to answera few questions for class set up.
  • What version of Arc Desktop are you brining?
  • Is it stand alone or a concurrent check out?
  • Do you have Data Interoperability installed or will you need a demo?
Thanks .
https://support.safe.com/KnowledgeDocumentation
http://cdn.safe.com/resources/fme/FME-Transformer-Reference-Guide.pdf
After you have read through the agenda, if you have any questions please feel to contact me.
  1. Food sources are pretty slim in Darien,  we can do an on your own or small registration fee for us to order in (subway, pizza, wraps)
  2. I will update my manual I have been editing and put together the changes I have made and upload it to the drop box under the name RegionW_v3
  3. https://www.dropbox.com/sh/vzw1ayvwppn3516/AADzgSmIxAbv7LycTLm0-HBQa?dl=0
  4. My hard drive that had the 10 meter DEM went out does anyone have a copy they could share?
