XY to Line OID Error (Error 000072), help?
1419
7
10-27-2021 10:51 AM
dzsiegel
New Contributor II
Hello,
I am working to create a set of Geodesic lines from a CSV file, however after using the XY to Line tool, I receive only two vastly incorrect lines, and several warnings ("Warning 000072: Cannot process feature with OID -1")
I've also tried to run the repair geometry tool suggested at the link for Error 000072, however, I haven't had any luck with that.
Any help is appreciated as I am a novice with ArcGIS.
Thanks!
JoeBorgione
MVP Esteemed Contributor
It works for me...
I made sure that the Lat Long data in the excel worksheet were numeric in type before converting it to a table.
That should just about do it....
JoeBorgione
I suggest you perform a table to table to convert your csv file into a file geodatabase table and then try it again.  You might also try first saving the csv to an excel worksheet and then apply excel to table converting it into a file geodatabase table.  I don't have a ton of faith in either csv or excel; I prefer a real-live database table on which to apply geoprocessing tools.
dzsiegel
New Contributor II
Hi Joe,
Thanks for your suggestion. After trying to convert from CSV to GDB and XLSX to GDB, and then applying the XY to Line tool, I still got the same error (000072), although slightly different. Instead of "Cannot process feature with OID -1" I got the error "Cannot process feature with OID 1," "Cannot process feature with OID 2," and so on.
This project is essentially me pulling historical movement data of people out of oral histories, so I have the freedom to choose how I input data, whether CSV, XLS, or otherwise, and I chose CSV since I figured it would be fairly hassle free. GeoJSON posed no issues importing to feature, but I wanted to cut out the GeoJSON coding step.
Do you have any suggestions for a more succinct input method?
Thanks for your help.
JoeBorgione
Any chance you can post a few records of your data in a csv file here?  I don't have any experience with that tool.
dzsiegel
New Contributor II
Sure, this is the only CSV file I have so far that I'm trying to produce lines from.
JoeBorgione
It works for me...
dzsiegel
New Contributor II
Thanks for your patience and showing me your work. I'm too embarrassed to say what the actual issue was, but it suffices to say that your screenshot allowed me to realize my very fundamental issue...
Cheers!
JoeBorgione
Let me guess: latitude and longitude values swapped?  Happens all the time! (I had to double check myself before I ran the tool...)
