Updating feature class metadata in model builder or python
3107
09-23-2011 11:48 AM
JessicaParteno
Is there a way to append information to the metadata of a feature class in model builder or in a python script. I want to create a script that copies data from SDE and archives it in a FileGDB but I need to add a date and information about the associated project phase to the metadata so that there is a record showing which stage in the project the data is referencing. I have a large number of feature classes that will have to be updated with the same information so I want to streamline this process. Any tips would be greatly appreciated.
Jessie
deleted-user-j8mLJlqlcYvr
Did you ever find a way to accomplish this?
TashaBartholomew
I am curious about this as well, I have a copy and paste system working at the moment, but wasn't sure if there was a way to do it within the model.
Thank you!
MattSayler
At 10.1, the only way I know of that might work is to export the metadata, which will be XML, use python to parse and edit the xml, and then import it back in. Wish I could give more, but I haven't had a chance to mess around with it yet myself.
Export/Import are geoprocessing tools in the conversion tool set
XML parsing and editing can be done with built in or 3rd party python modules: http://wiki.python.org/moin/PythonXml
I'd be interested to hear if you make any progress on this!
curtvprice
The other main approach is to become conversant with XSLT and merge the information in using the XSLT Transformation tool.
DavidlMason
Are there any new tools to modify metadata in ModelBuilder in ArcGIS Pro?
