Trouble with tool Geotagged Photos To Points
4036
13
09-14-2022 05:03 AM
CeciliaMartinelli
Hi, I'm trying to use the Tool Geotagged Photos To Points but I have the following error, that I don't understand:
Input Folder     E:\...\foto
Output Feature Class     C:\Users\HRT\Documents\ArcGIS\Packages\Irpinia_final_e31e05\p30\irpinia_final.gdb\foto_GeoTaggedPhotosToPoints2
Invalid Photos Table
Include Non-GeoTagged Photos     ALL_PHOTOS
Add Photos As Attachments     ADD_ATTACHMENTS
Messages
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\phototopoint.py", line 182, in <module>
    GeoPhotoToPoint(folder, fc, badphotostable, addnongps, attachphotos)
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\phototopoint.py", line 80, in GeoPhotoToPoint
    row = MakeRow(null, file, timestamp, x, y, z, direc)
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\scripts\phototopoint.py", line 128, in MakeRow
    if "T" in timestamp: # sometimes the timestamps are isoformat
TypeError: argument of type 'NoneType' is not iterable
Failed script (null)...
Failed to execute (GeoTaggedPhotosToPoints).
The photos have the same format, taken togheter, all have coordinates ... I tried to upload them on ArcGis one by one and for some of them the tool works, other it fails and I don't get on which basis. Does anyone know why and how to solve it?
In the attachments two examples: img1 doesn't work, img2 works
I'm using ArcGis Pro 3.0.0
RobCahalan1
Good call....the functionality is totally lost from Pro 3 but still remains in ArcMap 10.8.2.
AFackler_NAPSG
Hey all, I just talked with Esri Support about this and they confirm that this is an issue with Pro versioning and should be fixed in the next patch release of Pro. For now, workaround is to run the tool on a machine with version 2.9 or in ArcMap.
NigelEdmead
I've observed this same issue in Pro 3.0.3, it is working OK in 2.9.0.
DrewFlater
@CeciliaMartinelli and all, just to let you know, the issue has been resolved in ArcGIS Pro 3.1, which will be publicly available coming soon. And the fix is being backported to an ArcGIS Pro 3.0.x patch, which will probably be available around the same time (within a few weeks).
For Tech Support tracking, it is issue BUG-000152786
