TauDEM toolbox in ArcGIS 10.3
2242
07-12-2016 10:56 PM
justingeorge
I was trying to use TauDEm toolbox in Arcgis 103, but the following error is showing::
ret_ = setattr(self._gp, item, value) RuntimeError: Object: Error in accessing environment <outputCoordinateSystem>  Failed to execute (angle).Can anyone help?
XanderBakker
Esri Esteemed Contributor
The error seem to be referring to the output coordinate system in your geoprocessing environment ("outputCoordinateSystem").
Can you check what is specified in your case?
