I have a way around it. The reason I needed to do a spatial join was to be able to do a SUM over the point feature values in each parcel.The stat was done on a table of the joined data. I then rejoined the table to the already joined data with the multiple records for each Target_Fid. What I ended up doing is joining to the original parcel layer and hence only one record per parcel. Silly me.Thanks to all viewers!
