See all the values in the statistics field when dissolved
4704
13
06-16-2015 04:24 AM
SalmanAhmed
I am doing a simple dissolve on my data. I want to use a text field as statistics field and get all the values from that field and not just FIRST or LAST. Any possible way to do this?
Thanks.
SalmanAhmed
WesMiller
Salman do you have an Advanced license could you run feature to point on your small polygons and select the optional inside radio button. You should have points inside the polygons with the associated data you could then rerun the spatial join using the match option intersects and don't forget to set up your join field.
SalmanAhmed
Yes I have advanced license and this method work well. Its amazing how each thing can be done in a thousand ways in ArcGIS. Thanks alot for all the help!
SalmanAhmed
I just noticed that one another feature also is not listed. In the map its clearly again inside the big polygon but is not listed like Simmerath. There may be more. But why....
