"000599: Falls outside of output geometry domains"- With environment settings setup, why?
988
02-19-2020 06:07 AM
DávidGregor
New Contributor II
I wrote a tool what merges the same features classes from a series of gdb-s into one FC (and also does other things).
But i "get 000599: Falls outside of output geometry domains" error whatever i do.
I put this in the begining of updateParameters, also into the execute section of the tool, but nothing changes.
        arcpy.env.XYDomain = "-29338800 -33101500 900690586674 900686823974"
        arcpy.env.outputZFlag = "Disabled"
        arcpy.env.extent = "MAXOF"
        arcpy.env.outputMFlag = "Disabled"
this is my merge:
            fc = []
            walk = arcpy.da.Walk(workspace, datatype="FeatureClass")
            for dirpath, dirnames, filenames in walk:
                      for filename in filenames:
                         if key.lower() == filename.lower():
                                 fc.append(os.path.join(dirpath, filename))
            if fc:
                output_esri = os.path.join(mergeDir, os.path.basename(key))
                arcpy.AddMessage(len(fc))
                arcpy.Merge_management(fc, output_esri)
The tool works fine with Point type. But doesn't merge with polygon (the extent of the fc/gdb-s are totally different, there no Z value)
What do i miss?
edit: It works if i write it to shp and not GDB!
maybe important: The data is in this system
EPSG:23700
HD72 / EOV
