Query builder
2661
6
10-14-2014 12:42 AM
MassimoSpirlandelli
In my "level curves" (1 meter definition) shp file  I want to query:
- the pair numbers (for instance: 102, 104, 106, 108, 110 , ect. ect.)
- every five meters (for instance: 100, 105, 110, 115, 120, 125, ect. ect.)
How can I do quickly instead of select every single record?
Is there any query?
thank you
DanPatterson_Retired
if you have to do this with a lot of records, consider building a temporary field then you can query that field for the appropriate ranges  see the example of using the mod (%) function in python.  Unfortunately the query builder doesn't support native python at present.
JohannesBierer
With python:
for i in range(102, "End", 2😞
print i
MassimoSpirlandelli
could you explain me clearly with details (I have never used directly python) ?
JohannesBierer
The best is to create a model with select by attribute - then export the model to python and modificate the python code with the for i in range command?
MassimoSpirlandelli
ok but with query builder it isn't possible ?
MassimoSpirlandelli
THANK YOU !
easy and fast !!
