Python receipt in Calculate window
4414
06-08-2015 12:02 PM
D__SamuelRajasekhar
In Field calculator window I would check Python and String
"CAMGMT15" + str(!FID!)
What if I want to add say FIDs from 1 to 250,000 and I want it to be CAMGMT1500000001, ....  ,CAMGMT1500002346 so forth.
Eight spaces from CAMGMT15 and f
Thanks
JakeSkinner
Esri Esteemed Contributor
Hi D,
You could use the following expression:
"CAMGMT" + str(1500000000 + !FID!)
D__SamuelRajasekhar
Hello Jake,
Thanks for the answer. Awesome, such a short time. I used the below function and it seemed to work:
"CAMGMT15" + str( !FID!).zfill(6)
The trick seems to be zfill. And if I add too many letters in the first string say "CAMMGMTSQ15" and set the zfill value at 8, I am getting error. Obviously the 15 length I set for this field is exceeded.
