Python error: "Method RasterFieldName does not exist"
535
07-29-2010 05:55 AM
KateParks
I'm trying to write a python script that will print the name of a raster dataset to screen. I copied the example code from the Desktop Help and changed the raster object to match the path to my dataset:
import arcgisscripting
gp = arcgisscripting.create()
raster = "C:\data_all\AltLatGrids\ArcGISGrids\alb8__22"
# Create a describe object
desc = gp.Describe(raster)
# Print the RasterFieldName property
print desc.RasterFieldName
When I ran the script I received the error message "Method RasterFieldName does not exist". I am using ArcGIS 9.3 with an ArcInfo license, and Python 2.5.4.
Any help gratefully received!
Kate.
GerryGabrisch
Python is backslash sensitive.  Try:
raster = "C:\\data_all\\AltLatGrids\\ArcGISGrids\\alb8__22"
or
raster = r"C:\data_all\AltLatGrids\ArcGISGrids\alb8__22"
KateParks
I tried both of those, but still get the same error.
Out of interest, what does the 'r' before your second suggestion do?
GerryGabrisch
Ah,
RasterFieldName is not returning the name of the raster it returns the name of a field in a raster catalog.  See
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=1053&pid=980&topicname=Raster_Catalog_propert...
Try this
raster = r"C:\Temp\lidar"
# Print the name of the raster
print desc.Name
Backslashes are special characters, for example
print "Foo\nbar"  would print
foo
bar
to the screen.  The r sets the string to a raw string so r"Foo\nbar" would print
Foo\nbar
KateParks
Thanks a lot for your help, that works now.
