Problems with ASCII to Raster in ArcGIS Pro 2.6.x
5440
13
09-10-2020 04:53 PM
FrancesBiles1
This question is similar to the problem here
Today, using Pro 2.6.0, I used the Contour List tool to directly extract a contour line from an ESRI ASCII file (e.g., file1.asc).  For Input Raster I was able to select file1.asc by browsing to the file. It ran successfully.
I tried to run Contour List again, selecting file2.asc for the Input Raster, however, the file does not show up when browsing to it from the tool.  I can browse to and see the .asc files in Catalog, but cannot load them into a map window (the solution that worked for people in the above link) and they no longer show up when browsing to them in the tool.
Next, I tried to use Copy Raster to covert the .asc to a .tif first, then run Contour List. However the Copy Raster tool will not show .asc files either:
The ArcGIS Pro Copy Raster help here does not show .asc as a file option, but numerous other pages and help discussions say that 'Copy Raster' is the way to convert from ASCII to Raster now that the 'ASCII to Raster' conversion tool has been retired.
Next, I installed the Pro update to 2.6.1 and restarted the computer. Same result.
How can I get Pro to recognize the .asc files so I can convert them to a tif? Or use them in the Contour List tool directly? Note, I did see here that says you cannot use ASCII files in the Contour List tool directly, but it did work the first time I tried it and i have the geoprocessing history and resulting vector contour to prove it!  This is very perplexing!
Extra info: The .asc files were created from .tif files (DEMs) in Pro using the Raster To ASCII tool, then run through another piece of software (VDATUM) that exports results to ESRI ASCII format. When I open the .asc files in a text editor I see nothing wrong with them, except unfortunately the Pro Raster To ASCII tool uses the X & Y LL corner coordinates and the VDATUM software exports using the X & Y LL center coordinates. Grrr. Is there a way to convert from raster to ASCII in Pro and specify using the LL pixel center coordinate instead of the corner? A separate question, I know....
DanPatterson
MVP Esteemed Contributor
Tech Support then, since nothing else has helped
... sort of retired...
DanPatterson
check the ascii header
Release notes for ArcGIS Pro 2.7—ArcGIS Pro | Documentation
BUG-000128848 In ArcGIS Pro, an ASCII raster is not recognized if the header is in upper case
Fixed in 2.7 if that was the issue
qichitu
I have the same problems. I just drag the .asc file from the Catalog to the Contents, and it is displayed as raster. You can save the raster by context menu.
Arp_148
Would it be possible to look at that asc you are using to understand how its built? perhaps get a copy and try it out here? I do exactly the same but nothin appear on my map. Or I could send you mine and see if it pops up at your place?
