My Model crashes and closes down Arcmap
2629
03-27-2012 03:18 AM
by Anonymous User
Not applicable
Original User: GEOSTUV03
Hi there
I made this model, but whn I un it, it crashes down Arcmap.
I have tried ArcMap 10, SP3 and SP4 and it's on a windows 7, ENT x64
There is attached the model and the data.
Please help
SteveLynch
Henrik
Thank you for sharing the problem. It will be fixed in 10.1 and also in 10 SP5
The problem occurs when you have a feature class with an undefined extent. To create a raster one needs an extent.
FeatureToRaster and PolygonToRaster now throw an error when there is no extent.
In your workflow you'll need to make a decision what to do when a feature class with no extent is created. Possible solutions include, inter alia;
- stop processing, or
- define an extent and in your case a output raster filled with NoData will be created.
Once again, thanks
Steve
HenrikSvenningsen
Hi
I found the problem my self.
The LAN010 output was empty and therefor the "FC to Raster" crashed the model and ArcMap.....When I removed this "string" in the model, it worked just fine.
by Anonymous User
Not applicable
Original User: 1812
Henrik,
I am glad you posted the problem and the data. I have reproduced the crash and passed it to the team for investigation and hopefully a fix. Thanks for your post and the update.
SteveLynch
Henrik
Once again, thanks
Steve
