Modified date of feature class in SDE
8671
7
08-30-2010 09:21 AM
ChrisMathers
At 9.3.1 is there a way to get the date a feature class was last modified on a SDE?
We have a branch office that cant see our SDE and keep what little data they use on a server at their office in shape files. I want to write a script that would store the feature classes in a dictionary as 'name':'date' and keep the dictionary in a pickle. I would open the pickle in the script, compare the dates to the dates on the SDE and export the feature classes that have been updated to shape to FTP over to the other office. If its not possible at 9.3.1 is it possible at 10? IT has promised us 10 once 10sp1 comes out so I can keep doing the exports by hand till then and automate it after that.
KenHartling
I believe the GDB leaves this up to the underlying database.  So, if you are using oracle you could query all_tab_modifications to find out:
http://download.oracle.com/docs/cd/B19306_01/server.102/b14237/statviews_2097.htm
Other databases should have documentation on how to find this info as well.  If you are using versioning the story is a bit more complicated.  Let me know if you are using versioning and I'll try to point you to the correct doc for getting and understanding of the underpinnings of GDB versioning.
If you don't want to build your own connector to the database, GP provides the ArcSDESQLExecute() class to pass SQL through an ArcSDE connection.
See
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v00000057000000.htm
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//002z00000021000000.htm
Ken
ChrisMathers
Thanks Ken. We are using SQL 2009 for our DB. So I can get the date from arcpy.ArcSDESQLExecute()?
KenHartling
It should work with any ArcSDE connection.
Ken
brucereagan
Ken,
I am doing the same thing with versioning.  Can you point me to the additional information I would need to find the last modfication date of a versioned feature class in SDE (on Oracle 11 g if that matters).  I have used ARCSDESQLEXECUTE, I just can't get the correct date.
KenHartling
Ken,
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/A_quick_tour_of_versioning/00270000000... should explain the additional tables you will have to monitor for change in the versioning case.
You also should take a look at this forum post which should give you a number of ideas on how to track this: http://forums.esri.com/Thread.asp?t=215843&c=2&f=59
Ken
JohnLovato
Ken,
  I'm using the following query to get the last edit date for versioned feature classes:
SQL CODE
SELECT
    r.OWNER,
    r.TABLE_NAME,
    TO_DATE ('19700101000000','YYYYMMDDHH24MISS') + NUMTODSINTERVAL(r.REGISTRATION_DATE,'SECOND') REGISTRATION_DATE,
    m.STATE_ID,
    s.CLOSING_TIME EDIT_DATE
FROM
    <OWNER>.TABLE_REGISTRY r,
        SELECT
            MAX(m.STATE_ID) STATE_ID,
            m.REGISTRATION_ID
        FROM
            <OWNER>.MVTABLES_MODIFIED m
        GROUP BY
            m.REGISTRATION_ID
    ) m,
    <OWNER>.STATES s
WHERE
    r.TABLE_NAME NOT LIKE '%DIRTYAREAS' AND
    r.TABLE_NAME NOT LIKE '%LINEERRORS' AND
    r.TABLE_NAME NOT LIKE '%POINTERRORS' AND
    r.TABLE_NAME NOT LIKE '%POLYERRORS' AND
    r.TABLE_NAME NOT LIKE 'GDB_%' AND
    r.REGISTRATION_ID ( + ) = m.REGISTRATION_ID AND
    s.STATE_ID = m.STATE_ID
ORDER BY
    m.STATE_ID DESC
Substitute <OWNER> for the name of your geodatabase owner in the SQL above.
I wrote the following geoprocessing script tool In Python for the user to use with ArcToolbox:
GUI
GUI VALIDATOR CODE
# -*- coding: utf-8 -*-
# GetVersionedEditDates_Validator.py
# Created on: 2015-06-03
#   John P. Lovato
# Description:
#   Validator for GetVersionedEditDates script tool.
# Updated on:
#   2015-06-03 by John P. Lovato - Created.
import arcpy
class ToolValidator(object):
  """Class for validating a tool's parameter values and controlling
  the behavior of the tool's dialog."""
  def __init__(self):
    """Setup arcpy and the list of tool parameters."""
    self.params = arcpy.GetParameterInfo()
  def initializeParameters(self):
    """Refine the properties of a tool's parameters.  This method is
    called when the tool is opened."""
    # disable the CSV File location parameter on start up
    self.params[3].enabled = 0
    return
  def updateParameters(self):
    """Modify the values and properties of parameters before internal
    validation is performed.  This method is called whenever a parameter
    has been changed."""
    # toggle the state of the CSV file location parameter baed on
    # checkbox.
    if self.params[2].value == True:
      self.params[3].enabled = 1
    else:
    return
  def updateMessages(self):
    """Modify the messages created by internal validation for each tool
    parameter.  This method is called after internal validation."""
    return
STANDALONE PYTHON SCRIPT
# GetVersionedEditDates.py
# Created on: 2015-06-02
#   John P. Lovato
# Description:
#   Displays registration date and last edit date for versioned objects
# Arguments:
#   <SDE_Workspace> - Workspace connection.
#   <GDB_Owner> - Geodatabase Owner (User who owns GDB metadata tables)
#   <Write_CSV> - Should the results go to a CSV file.
# Updated on:
#   2015-06-03 by John P. Lovato - Added parameters for writing csv file and code
#                                   for creating CSV file.
import arcpy, sys, os, datetime, csv
from arcpy import env
from datetime import datetime
# SDE Workspace
sdeWorkspace = arcpy.GetParameter(0)
# GDB Owner
gdbOwner = arcpy.GetParameter(1)
# Write CSV
writeCSV = arcpy.GetParameter(2)
# CSV File
outputFolder = arcpy.GetParameterAsText(3)
# Establish the gp workspace
env.workspace = sys.path[0]
# Create the SDE Connection
sdeConn = arcpy.ArcSDESQLExecute(sdeWorkspace)
# Build the SQL Statement for last versioned edits (DML changes only)
SQLStatement= """SELECT
    r.OWNER,
    r.TABLE_NAME,
    m.STATE_ID,
FROM
        SELECT
            m.REGISTRATION_ID
        FROM
        GROUP BY
            m.REGISTRATION_ID
    ) m,
    <OWNER>.STATES s
WHERE
ORDER BY
    m.STATE_ID DESC"""
# Customize the SQL Statement
SQLStatement = SQLStatement.replace('<OWNER>',gdbOwner)
# Display the SQL Statement
arcpy.AddMessage("\n" + SQLStatement + "\n")
# Pass the SQL statement to the database.
sdeReturn = sdeConn.execute(SQLStatement)
if writeCSV:
    # Directory of current script
    dirScript = os.path.dirname(__file__)
    # Output Folder
    if outputFolder:
        dirScript = outputFolder
    # Report Date
    reportDate = str(datetime.now()).replace(' ','_').replace(':','-').replace('.','-')
    # Output File
    outputFile = os.path.join(dirScript,gdbOwner + '_DML_Modified_' + reportDate + '.csv')
    arcpy.AddMessage('Report will be written to ' + outputFile + '\n')
    # Display the header to output
    arcpy.AddMessage('{:<30}'.format('OWNER')+' '+'{:<30}'.format('TABLE')+' '+'{:^21}'.format('REG_DATE')+' '+'{:^8}'.format('STATE_ID')+' '+'{:^21}'.format('EDIT_DATE'))
    arcpy.AddMessage('{:<30}'.format('------------------------------')+' '+'{:<30}'.format('------------------------------')+' '+'{:^21}'.format('---------------------')+' '+'{:^8}'.format('--------')+' '+'{:^21}'.format('---------------------'))
    # Display (and capture) the results
    with open(outputFile, 'wb') as csvfile:
        csvwriter = csv.writer(csvfile)
        # write the header
        csvwriter.writerow(['OWNER','TABLE','REG_DATE','STATE_ID','EDIT_DATE'])
        for sde in sdeReturn:
            arcpy.AddMessage('{:<30}'.format(sde[0])+' '+'{:<30}'.format(sde[1])+' '+'{:<21}'.format(sde[2])+' '+'{:^8}'.format(sde[3])+' '+'{:<21}'.format(sde[4]))
            csvwriter.writerow([str(sde[0]),str(sde[1]),str(sde[2]),str(sde[3]),str(sde[4])])
        arcpy.AddMessage("\n+++++++++\n")
else:
    # Display the results only
Hope this helps you.
Sincerely,
John P. Lovato
USDA Forest Service
Geospatial Database Engineer
Joel-Hickok-1978
In 2019 using SQL Server, this is how I do determine what the last edited date was for all rows in a feature class.  In my script where I use this code, I also have fallback code to handle situations where there is no last_edited_date values in the table, or where editor tracking is not enabled (this happens for our organization sometimes, hence the need for extra code).
* Note: One reason for this approach is that ArcPy should be handling any versioning scenarios, but you may want to investigate the results of using versioning and ensure to run a compress and then make sure the last_edited_dates are what you expect before/after a compress.
Steps
  1. Get cursor using a SQL Clause that only returns one row by using TOP 1 and ORDER BY in DESC order.
  2. Use list comprehension or some other method to reduce the resulting row(s) to a single value.
  3. Optional: localize the date so when you do comparisons to another date value, you can work with common timezone.
  4. Compare the last edited date with a "last synced date" you maintain in a JSON file or using Python pickle.
# which feature class to find last_edited_date field
fc_path = os.path.join(sde_connection_file, fc_name)
# list of fields needed for tasks
fields = [last_edited_date]
# sql_clause for SearchCursor argument to find only the one row with the most recent last_edited_date
sql_clause = ('TOP 1', 'ORDER BY last_edited_date DESC')
try:
   # execute cursor query
   rows = arcpy.da.SearchCursor(in_table=fc_path, field_names=fields, sql_clause=sql_clause)
   # list comprehension to create list with only the necessary field at row index position 0
   # should only be one value in resulting list due to use of the 'TOP 1' sql clause
   # then get the resulting value at position 0
   last_edited = [row[0] for row in rows][0]
   # localize the date to UTC for a common timezone spec and to make the datetime object timezone aware (aka not naive)
   last_edited_utc_date = utc.localize(last_edited) if last_edited else None
except Exception as e:
   print(e)
