Hello everyone, I want to have details about all variables used in model builder. Is there any website link? Actually I want to understand the basic concept that how I can use "select layer by attribute" as model parameter. I want to use start date and end date as my model parameter.
Thanks............ These videos seem to be very helpful. But have you created any parameter for start date and end date? If you could guide me in that regard.
It sounds like you are looking for the for loop, e.g. for it meets a condition such as date range then run....
I guess you can give the details of your needs so that others can jump in to help.
Actually I want to "select data by attribute" and then the further analysis on that and my attribute is date here. I want to create two date variables as model parameters. One for Start date and one for End date just to select a range of date from which my data should be selected.
It sounds like you want to use variable substitution. This is a common case -- have the user enter some data and then build a query based on the data the user enters. In this case, it's a couple of dates.
I'm going to refer you to a couple of help topics.
First, look at the Quick Tour about variable substitution.
