Merging a country back together
4297
01-25-2015 10:42 AM
jenniferstarbuck
I have taken a country and split the vector data for this country into 1 degree by 1 degree cells (tie edge between two cells) and now I need to combine the different data cells back together. I use to do this manually ex... I have roads snapped together meeting along the tie edge but are no longer one road (merged) because I have to split the data apart.  I use to go a long the tie edge and manually select the two road segments and merge them back together.  What I am wanting to know is there an automated process that can merge data back together that is snapped at a tie edge. I need to do this for lines and polygons
Thank you for any help or ideas.
DanPatterson_Retired
havent tried it in years, but Dissolve with unsplit lines looks promising ArcGIS Help (10.2, 10.2.1, and 10.2.2)
jenniferstarbuck
Do you know if there is away to use a buffer to set a work environment and merge the features within the buffer?
never tried it...sorry
