I would like to dissolve or merge records by the street name AND have separate records if there is an address gap. For example:
Input Table: (street name, low, high)
3rd Street 100-199
3rd Street 200-299
3rd Street 300-399
3rd Street 500-599
3rd Street 600-699
5th Street 600-699
5th Street 800-899
Desired Output:
3rd Street 100-399
3rd Street 500-699
5th Street 600-699
5th Street 800-899
Currently I can use Dissolve and use add the statistics for Min of low and Max of high which will create a simple dissolve, however I would like to find where there are gaps in the address.
Current (undesired results) using dissolve and statistics fields
3rd Street 100-599
5th Street 600-899
Questions:
Is it possible in ArcGIS, or Excel, or anything else to dissolve records together, but only if there is no gap in an address range? please note: I will need to know how to do this within the table view as I will be comparing a spatial dataset to a non spatial dataset.
Note: I should mention that what I need is very close to Dissolving using the Unsplit lines option. The unsplit lines option will only dissolve records if the two input lines have a end vertex in common. However, I need to figure out how to duplicate the "Unsplit Lines" option at the tabular level.
I think what you need to do is to create a second dissolve field that increments whenever there is a break, and use the address fields and the dissolve field as dissolve fields. You could use a sorted search cursor (the old flavor is easiest arcpy.UpdateCursor) and have a loop that walks through in order.
