Merge annotation from all CAD files in a given directory
1247
01-28-2011 07:50 AM
JayJohnson
I'd like to create a ModelBuilder model that I can point to a directory and have the model merge all the annotation from every single DWG file that is within that directory.  I can do this if I manually select each DWG file and the annotation layer within each CAD file, but I don't want to have to manually select each input dataset, but rather just point to the directory and let the model iterate automatically.  Ideas?
Jay Johnson
Reno, NV
FrankVignati
did you find a way to do this?
FrankVignati
Jay Johnson
Reno, NV
you may have to create an empty anno feateature class first then in the model use the Iterate Datasets tool to select each dwg and convert it to geodatabase features then select the anno using the new Select Data model tool and append it to the anno feature class you created
Iterate Dataset doc: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Iterate_Datasets/00400000000q000000/
Something like this
MichaelRobb
Honored Contributor
I know this is an old thread, but...
If anyone comes across this, the above post (#3) does not work.
CAD dataset type is not a means to select .dwgs, the model above does not work.
