The following script runs successfully, but no output is added to arcmap or arcgis explorer desktop. Any suggestions?Can I save the output to a layer file via code or script?##====================================
####Usage: MakeImageServerLayer_management in_image_service out_imageserver_layer
## {template} {ID;ID...} {mosaic_method}
## {order_field} {order_base_value} {lock_rasterid}
try:
import arcpy
arcpy.env.workspace = r"C:/workspace"
input1 = "http://splitboard/ArcGIS/services/imageryData_Mosaic/ImageServer"
arcpy.MakeImageServerLayer_management(input1, "mdlayer", "431778.367783651 4583563.68601919 432331.485840777 4583563.68601919", "1;2;3;4",\
"LockRaster", "#", "#", "1")
print arcpy.GetMessages()
except:
print "Make Image Server Layer example failed."
