Loop through feature datasets in a gdb
7372
11
02-22-2020 01:27 PM
MalcolmLittle1
New Contributor II
Hello,
Im using modelBuilder to attempt to create polygon datasets for each feature dataset in a geodatabase. Each feature dataset has a set of point feature classes, some for Weekdays (*WD*) and some for Weekends (*WED*):
I want to merge the point feature classes into one (based on wildcard for *WD* or *WED*), then perform a spatial join with an existing polygon feature. This is the model I have constructed so far:
Thing is, whatever I attach to Collect Values, be it a submodel that Iterates Datasets, then feeds that into Iterate Feature Classes, there's no resulting spatially joined polygon feature, or the resulting polygon feature is including everything in the gdb.
What is required to merge just feature classes inside a feature dataset, then loop through a whole geodatabase full of feature datasets?
DavidPike
MVP Frequent Contributor
import os
import arcpy
#enter your fgb input and output paths here
file_gdb = r'your gdb to loop thru'
output_gdb = r'output gdb'
arcpy.env.workspace = file_gdb
datasets = arcpy.ListDatasets("", "Feature")
fd_path_list = [ ]
fd_name_dict = { }
for feature_dataset in datasets:
    fd_path = os.path.join(file_gdb, feature_dataset)
    fd_path_list.append(fd_path)
    fd_name_dict[fd_path] = str(feature_dataset)
print(fd_name_dict)
for fd in fd_path_list:
    fc_path_list_WD = [ ]
    fc_path_list_WED = [ ]
    arcpy.env.workspace = fd
    featureclasses = arcpy.ListFeatureClasses()
    for fc in featureclasses:
         if "_WD" in fc:
            fc_path = os.path.join(fd, fc)
            fc_path_list_WD.append(fc_path)
         if "_WED" in fc:
            fc_path_list_WED.append(fc_path)
    wd_path = os.path.join(output_gdb, fd_name_dict[fd])
    print(fd_name_dict[fd])
    wd_path = wd_path + "_WD"
    print(wd_path)
    if len(fc_path_list_WD) != 0:
        try:
            arcpy.Merge_management(fc_path_list_WD, wd_path)
        except:
            continue
    wed_path = os.path.join(output_gdb, fd_name_dict[fd])
    wed_path = wed_path + "_WED"
    print(wed_path)
    if len(fc_path_list_WED) != 0:
        try:
            arcpy.Merge_management(fc_path_list_WED, wed_path)
        except:
            continue
    del fc_path_list_WD
    del fc_path_list_WED
print("done")
DavidPike
If you want those as a script it should be pretty easy and I'm happy to help, though I understand that might not be the point. I'm happy to admit my knowledge of model builder is limited!
MalcolmLittle1
New Contributor II
Running scripts through the Python console is also acceptable.
DavidPike
The only thing is the spatial join. What are the shapefiles and how are they structured? I'll need to define this in the code
MalcolmLittle1
New Contributor II
The point feature classes in this image are in their own feature datasets (e.g. A1006_subject feature dataset) in one geodatabase:
The polygon target feature of the spatial join is located in another geodatabase.
DavidPike
Yes but I need to know what the target shapefiles look like
MalcolmLittle1
New Contributor II
In all honesty, if the script can create merged point feature classes, the spatial joining portion I can easily run after, in a modelbuilder model.
DavidPike
import os
import arcpy
fd_path_list = [ ]
fd_name_dict = { }
print(fd_name_dict)
         if "_WD" in fc:
         if "_WED" in fc:
    print(wd_path)
        try:
        except:
            continue
    print(wed_path)
        try:
        except:
            continue
    del fc_path_list_WD
print("done")
MalcolmLittle1
New Contributor II
Put that into the console, but it gave an error:
I think the for loop doesn't retain information on the feature dataset location.
DavidPike
yes, thought the list() was retuning objects..
I've edited the code in my original reply which should work.
