Labeling issues/bug with layer of selected features in ArcMap 10.5
6244
18
10-17-2017 10:09 AM
Kevin_ASieger
New Contributor III
I'm having labeling issues in ArcMap 10.5 with lines and polygons layers created from a selection, I have not tried to label a selection of points but I'm guessing the issues is the same.
1. I select features for my map and create a layer of my selection.
2. I open the Layer Property window for the new layer that contains the selected features.
3. Under the Label tab I check 'Label features in this layer', change the Label Field and click OK.
4. The window closes and all features from the layer I selected from appear with the label I selected.
Some things I found that need to be noted about this issues/bug:
1. If I create a layer of my selections and on turn on the label but not change the Label Field everything is good to go, the layer of selected features appears as it should with 'default' label. The only work around I have is to create a Shapefile of my selection.
2. I don't have to turn labels on to have this happen, all I have to do is change the Label Field.
3. If I open the attribute table of the layer created from my selection only the selected features are in the table, but after I close the attribute table and go through the steps above all features from the source layer appear.
JasonGlatz
I'm getting the same behavior. I'm running 10.5.1 on Windows 10. I uninstalled and reinstalled the program, but that didn't fix the issue. In case the original poster's issue isn't totally clear, the problem is that when you apply any change to a layer created by selecting features, the change erases the selection and applies to all of the features in the layer (e.g. if you select 5 of 10 polygons, create a layer, symbolize it (lets say make it green rather than yellow) and then make any change to the labels, all 10 polygons will change. You will have 10 green polygons rather than 5 yellow and 5 green). The only other piece of information that I can add is that changing the placement properties (without even applying the labels) creates the same problem.
Edit: Downgrading to 10.5 solved the problem for me.
Kevin_ASieger
New Contributor III
I've also had the same issue with selecting lines but have not had a need to see if the same thing happens with points.
Reply
PhilippConner
I can confirm that this happens with points as well in 10.5.1 for me. That being said, this looks like a relatively old issue, Given Kevin's findings in other threads.
https://community.esri.com/message/734783-re-selections-saved-as-layers-revert-to-original-table
RusselTaylor
New Contributor II
I've had this problem for several versions of ArcGIS now, but it seems to have gotten much worse with 10.5.1.
Reply
Kevin_ASieger
New Contributor III
I've been using the software since 3.2 and have never run into this issue until we upgraded to 10.5.
Reply
JasonBarnes1
New Contributor II
I'm having the exact same issue. As soon as I go to layer properties on a selection layer, and hit OK, I completely lose the selection. This is very annoying. Has anyone found a workaround/fix?
Reply
Madanbhurati
New Contributor III
As far as you preserve the selection in parent layer it works fine. even if you change the labeling field it shows only selected labels in selection layer. once you release your selection in parent layer and try to refresh the layer by switching on/off it displays all the features. as both the layers are pointing to same underlying data source it may preserve it until the selection was preserved. I tested it in 10.5, I am not sure how was the behavior in 10.3.
Reply
JasonBarnes1
New Contributor II
Unfortunately this is not the case for me. Even while preserving the parent layer selection I lose the selection in the selected layer. 10.5.1.
Reply
NaomiBegg2
Occasional Contributor III
I have also tried to preserve the parent layer selection but I too am loosing the selected layers. 10.5.1
Reply
