KML & ArcGIS 10
721
02-05-2011 03:18 PM
MitaSom
With 9.3 I could use KML for the Google Map. I dnloaded KML script, but when I go to extension I do not see KML extension which I had in 9.3 without problem.
So will anyone tell me 1. 2. 3. steps how to import a shape file into Google Map with ArcGIS10.
Thank you very much in advance.
Mita
MitaSom
I think I little bit solve my problems. I had to save my shape files as layer. Then go to ArcCatalog conversion tool to export.
Then in google earth I add that KMZ. file.
But there could be better way. For now it will help me.
Mita
TrixieRife
toolbox: conversion tools: To KML. you can convert the entire map or just the layer. If you have any 3D images in the layers, they don't seem to come through in 10, like they did in 9.3, but the symbols in the map or layer will.
