Iterate clip of polygon fcs by boundary polygon fcs of same name?
942
01-20-2021 06:57 PM
KathleenHoenke
I have a gdb of 50 polygon fcs named based on state abbreviation - ie: AR_HUC12, AL_HUC12, etc.
I have another gdb of polygon fcs also based on the same state abbreviation - ie:  AR_wetlands, AL_wetlands.
I want to create a short scripts that loops through the second gdb and clips each of these fcs by the fc in the first gdb that has the same name. For example, I want to take the fc named AR_wetlands and clip it by the fc named AR_HUC12.
Is there a quick script that will do this? I am very much a beginner!
Tags (3)
DavidPike
MVP Frequent Contributor
it's not going to win any beauty contests, but it'll work (underlying premise is that everything before the _ in your fc names matches in each fgdb).
import arcpy
import os
#not a fan of stating the obvious, but change the paths below to your fgdbs
#also keep the r then surround the path in quotes
#fgdb of features being clipped
source_fgdb = r'D:\a.gdb'
#fgdb of features doing the clipping
clipping_fgdb = r'D:\b.gdb'
#preferably empy fgdb to put outputs
output_fgdb = r'D:\c.gdb'
#list all the feature classes
arcpy.env.workspace = source_fgdb
source_fcs = arcpy.ListFeatureClasses()
arcpy.env.workspace = clipping_fgdb
clipping_fcs = arcpy.ListFeatureClasses()
#make a dictionary of source fc path
#to clipping fc and source name
#NB relies on names before the '_' being equal
source_clip_fc_dict = {}
for source_fc in source_fcs:
    for clipping_fc in clipping_fcs:
        if source_fc.split("_")[0] == clipping_fc.split("_")[0]:
            source_fc_path = os.path.join(source_fgdb, source_fc)
            clipping_fc_path = os.path.join(clipping_fgdb, clipping_fc)
            source_clip_fc_dict[source_fc_path] = [clipping_fc_path, source_fc]
#clip each source feature and output to output_fgdb
for source_fc_path in source_clip_fc_dict:
    clipping_fc_path = source_clip_fc_dict[source_fc_path][0]
    source_fc_name = source_clip_fc_dict[source_fc_path][1]
    out_fc_name = source_fc_name + "_Clip"
    out_fc_path = os.path.join(output_fgdb, out_fc_name)
    arcpy.Clip_analysis(source_fc_path, clipping_fc_path, out_fc_path)
DavidPike
import arcpy
import os
KathleenHoenke
Thank you so much, I sincerely appreciate it!
I'm wondering what I'm doing wrong, if I were to use and alter this same script to do an extract by mask with rasters?  See below. I'm  good in model builder, but just learning arcpy!
DavidPike
No problem, also if you think that's the correct answer please mark it so.
I'd recommend stating this as a new problem in the forum, stating what you intend the script to do exactly, and then actually post the code as text (properly formatted) as a screenshot is maybe ok for capturing what an error message looks like, but not blocks of code someone would have to type out to correct/modify.
