Is the “Manage Tile Cache” geoprocessing tool designed for 64-bit multiproceesing?
787
05-11-2017 04:14 PM
MarkMindlin
I have noticed that
This tool supports the Parallel Processing environment setting.”
http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/manage-tile-cache.htm
But it is not clear if it is relevant to 64-bit environment.
DanPatterson_Retired
see this blog... it still applies https://blogs.esri.com/esri/arcgis/2015/02/06/analysis-geoprocessing-in-arcgis-pro-frequently-asked-...
there are other similar posts and blogs, in short, one doesn't mean the other and all can work in concert
MarkMindlin
Thank you Dan,
I understand the meaning better now.
From the testing I see that  __the tool__  in 64BG runs slower with AOI specified.
Uninstalled.
