I have been using the intersect tool between two fairly large shapefiles (one has about 30k records, the other is the census blkgrp.shp from ESRI Data&Maps, so about 211k records) within a python script for the past year or so without any issues. Recently (within the past week) it has not been completing the intersect - there hasn't been an error returned, but the tool just gets hung up. I just tried to complete the intersect between these two shapefiles manually within ArcMap, and I noticed in the results window that the most recent message is "Processing Tiles", but the Percentage at the bottom of the screen is stuck at 0%.
Neither of the shapefiles seem to be corrupt. I'm using ArcGIS 10 (ArcEditor license level) with Service Pack 4 and the most recent patch installed.
I'm at a loss since I've been using this data/tool for awhile with no problems, and I'm not sure what's causing the tool to fail. Any insight/suggestions on what to try is appreciated!
