Inserting Current Date into Filename via Modelbuilder
23129
17
02-04-2011 05:46 AM
JeffPickles
New Contributor III
Is there a way to programmatically export a shapefile or feature class from Modelbuilder that has the current date in its filename?
KevinHibma
Jeff,
I'm assuming you're on 10.
Check the toolbox I've attached. You dont need to script this.
You'll see its just a copy features and a Calc Value.
The Calc value has a python snippet to calc the date. The output of this is "outDate"
I've then used the inline variable %outDate% as the name of the featureclass.
I grabbed the snippet from:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Calculate_Field_examples/00170000004s0...
Depending on how you write out
time.strftime("%d/%m/%Y")
(d/MM/yyyy etc etc), you can get different dates. Also remember the featureclass name cant start with a number.
RyanStillman
New Contributor II
I was googling how to do something similar and this little discussion eventually lead me to my solution.
It can be done by placing a Calculate Value Tool in your model and setting its expression to:
time.strftime("%Y%m%d")
The output value will be a date or time in the format you specify between the "s. This link has a nice table with helpful explanations about the different date and time formatting options and possible associated limitations or restrictions: 8.1. datetime - Basic date and time types - Python v2.7.8 documentation‌.
My example has the particular format(%Y%m%d) such that if the model were run on June 8, 2001, the output value from the tool would be the string '20010608'.
You can then rename the output value(green bubble) to ANYTHING and then elsewhere in your model you can reference that value by inserting %ANYTHING% into filenames or location dialogues throughout the rest of the model, just like other in-line variables.
I hope this helps you out, 3½ years late, or more likely, somebody else with the same question.
SaraBarnes
Thanks for posting Ryan Stillman‌ - your late reply helped me figure this out!
JulieScott-Ashe1
New Contributor II
Thank you for posting this - it worked perfectly.
JasonHrubizna
New Contributor III
Helped me too, thanks for posting!
curtvprice
MVP Esteemed Contributor
The Calculate Value tool really makes Model Builder​ a lot more useful -- and a little Python knowledge goes a long way with that thing!
NedCake1
Works great! Thanks for the post.
DianaHutt
New Contributor II
Thank you!!
AurelijaViluckyte
Worked for me also, thanks mate!
