Import Cad Annotation - unable to get an ArcGIS 9.2 script to function with ArcGIS 10
1002
02-21-2013 10:49 AM
BrentEdwards
Here is a snippet from the functioning ArcGIS 9.2 script :
for item in lst_dxf_o_files:
                gp.MakeFeatureLayer_management(item + os.sep + 'Annotation', 'tmp_3rayon_lyr', "UPPER(layer) LIKE 'OFF_LO_RAY' AND UPPER(txtmemo) LIKE 'R: %,%'")
                print unicode(gp.GetMessages()).encode("iso-8859-2", "replace") + "\n"
                lst_anno_lyrs.append('tmp_3rayon_lyr')
                gp.MakeFeatureLayer_management(item + os.sep + 'Annotation', 'tmp_4pc_lyr', "UPPER(layer) = 'GRA_NM_PLA_COM' AND UPPER(txtmemo) LIKE 'PC%'")
                lst_anno_lyrs.append('tmp_4pc_lyr')
# Process: ImportCADAnnotation
gp.ImportCADAnnotation(';'.join(lst_anno_lyrs), tmp_an, 1000, "ONE_CLASS_ONLY", "NO_MATCH", "NO_SYMBOL_REQUIRED", "STANDARD", "", "NO_AUTO_CREATE", "NO_AUTO_UPDATE")
And here is the non-functioning ArcGIS 10 version:
                arcpy.MakeFeatureLayer_management(item + os.sep + 'Annotation', 'tmp_3rayon_lyr', "UPPER(layer) LIKE 'OFF_LO_RAY' AND UPPER(txtmemo) LIKE 'R: %,%'")
                print unicode(arcpy.GetMessages()).encode("iso-8859-2", "replace") + "\n"
                arcpy.MakeFeatureLayer_management(item + os.sep + 'Annotation', 'tmp_4pc_lyr', "UPPER(layer) = 'GRA_NM_PLA_COM' AND UPPER(txtmemo) LIKE 'PC%'")
arcpy.ImportCADAnnotation_conversion(';'.join(lst_anno_lyrs), tmp_an, 1000, "ONE_CLASS_ONLY", "NO_MATCH", "NO_SYMBOL_REQUIRED", "STANDARD", "", "NO_AUTO_CREATE", "NO_AUTO_UPDATE")
And here are the errror messages:
GP ERRORS:
ERROR 000021: Failed to create the output annotation feature class
Failed to execute (ImportCADAnnotation).
PYTHON ERRORS:
Traceback Info:
  File "D:\workspace\Scripts\cadastre\_pour_v_\_Outils_\Scripts\Copie de 01_urb_cad_projete_chargement.py", line 78, in <module>
Error Info:
    <class 'arcgisscripting.ExecuteError'>: ERROR 000021: Failed to create the output annotation feature class
I noticed that the Make Feature Layer (Data Management) documentation at both versions mentions the following limitation regarding the <in_features> parameter:
"Complex feature classes, such as annotation and dimensions, are not valid inputs to this tool."
I have also experimented with using the python list directly for the input_features parameter, but I still get the same error. The output workspace is a PGDB for the relavant version (9.2 vs. 10).
Cheers for any insight!
JakeSkinner
Esri Esteemed Contributor
Hi Brent,
Try replacing:
arcpy.ImportCADAnnotation(';'.join(lst_anno_lyrs), tmp_an, 1000, "ONE_CLASS_ONLY", "NO_MATCH", "NO_SYMBOL_REQUIRED", "STANDARD", "", "NO_AUTO_CREATE", "NO_AUTO_UPDATE")
with:
BrentEdwards
Hi Brent,
Try replacing:
with:
Good eye. The "_conversion" is present in the actual script and it still does not work. I have corrected the post according.
