Identify Route Location Results dialog has gone missing
2041
07-25-2012 11:06 AM
KennethPierce
I have a machine running ArcGIS 10 SP3 which no longer shows the route location dialog when a route is selected with the identify measure tool. I had a potentially similar problem with table attributes window which needed to be reset using regedit as in this kb
http://support.esri.com/en/knowledgebase/techarticles/detail/29236
I'm running win 7 64-bit premium. Anyone have any ideas?
Aneel_Kumar_M
I am also facing same issue, route location dialog is not showing when a route is selected with the identify measure tool
Please share, if you have any ideas., thank you
